Need help with offsets
Old Oct 1, 2008 | 05:37 PM
buddyleee5's Avatar
buddyleee5
I realize that from the other threads on here 22's are not a big hit, but i personally like the style. I was hoping that you could put aside your difference in opinion and help me with what offset i would need to run a set of staggered 22's. I was also wondering if a 22x10.5" wheel will be too wide for the back. Any help is appreciated. thanks
Old Oct 1, 2008 | 05:40 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Deeyaum... Deuce Deuce's huh? Not sure on offsets but 10.5 in the rear would be rubbin like a fat lady's thighs do while runnin a mile...
Old Oct 1, 2008 | 06:30 PM
GiGGaplease's Avatar
GiGGaplease
dang, post pictures when you get the wheels.
10.5 will fit. solo have 21x11 in the rear i believe. 35ish would be a good offset.
Old Oct 1, 2008 | 06:53 PM
buddyleee5's Avatar
buddyleee5
i'm in new england, so the wheels may not actually be on the car until next spring because that white stuff that falls from the sky and ruins all the fun is coming soon
Old Oct 1, 2008 | 07:52 PM
Kidcane's Avatar
Kidcane
Florida G Club
10.5 will work fine as long as you stay around +35 or higher, like gigga said. I would not go higher than 45 though.
Old Oct 1, 2008 | 08:23 PM
buddyleee5's Avatar
buddyleee5
+35 on the front and the back? the fronts are 22x9
Old Oct 1, 2008 | 09:45 PM
GiGGaplease
+30-35ish front would be good. youre going to drop it?
Old Oct 1, 2008 | 09:56 PM
buddyleee5's Avatar
buddyleee5
i'm not planning on it, no
Old Oct 1, 2008 | 10:29 PM
GiGGaplease
oh, you probably wont need it anyways
Old Oct 3, 2008 | 08:34 PM
buddyleee5's Avatar
buddyleee5
as long as it doesnt rub, maybe my thinking is wrong, but when i put a set of 20's on and drop the car to fill the wheel wells it just puts me at a higher risk of hitting something on the bottom of the car. If i do the 22's and fill the wheel wells and i dont drop it i risk having a skinny tire and doing damage to the rim, but thats much easier to fix then something in the underbody of the car
Old Oct 4, 2008 | 10:51 AM
buddyleee5's Avatar
buddyleee5
I found a set of 22's locally with a +35 offset on a 08 g35 sedan, is there any differences between the fit on the sedan and our coupes? He didnt list how wide the rims were but said there is no rubbing on his sedan
Old Oct 4, 2008 | 12:30 PM
Kidcane's Avatar
Kidcane
Florida G Club
Sedans usually run a little less wide. Better find out.
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
