Lug Nut Problem in rear wheels
I'm running a 10.5" wide wheel with a +30 offset. I'm using Tuner Lug nuts for now and they fit well in the front but in they back they stick out too far. Can anyone suggest what size Tuner Lug nuts I can use to make them sit inside the wheel like the fronts do. My rear is 20X10.5 +30 Offset. Front 20X8.5 +30 Offset I'm also looking for lug nuts with wheel locks for those sizes if you can suggest any.
Well I don't think your gonna be able to do that on this car... I have Volks on my car.. With a 35mm offset on the front and a 37mm offset on the rear... I have Rays engineering forged lugs on my car.. And I have the same issue that you have.. The Lus stick out on the rear and in the front they sit further inside..... I don't know if you are gonna be able to get rid of this.. I personally like the way it looks
RAVSPEC
Wheel & Tires
Aug 5, 2015 03:55 PM
