dont know what to do...
Old May 16, 2008 | 02:03 AM
johng35m's Avatar
johng35m
Alright heres the deal. I have 20' Iforged.
I am dropped on Tein H-techs
The tires sizes are:
Yokohama S-drives
285/30/20
245/35/20
I trimmed the metal bracket and cut the liner. I still rub when I hit dips not even going that fast. but i dont want that to happen. do you think if i go with 275/30/20 on the rear, it would fix this problem? should i change springs? please help
Old May 16, 2008 | 03:27 AM
TerribleONE453's Avatar
TerribleONE453
what are your offsets?
Old May 16, 2008 | 08:55 AM
IP37's Avatar
IP37
^x2. and how bad is it rubbing
Old May 16, 2008 | 11:45 AM
johng35m's Avatar
johng35m
iforged doesnt release their offsets. it rubs when i hit a dip or a bump on the road
Old May 16, 2008 | 11:49 AM
gan78mao's Avatar
gan78mao
does it rub all the time? does it bug u that much?
going down to 275 might help a little bit!
Old May 16, 2008 | 12:14 PM
johng35m's Avatar
johng35m
it rubs almost everytime i hit a dip or bump. i havent went on the freeway yet but im pretty sure ill rub a lot.
Old May 16, 2008 | 12:22 PM
gan78mao's Avatar
gan78mao
is it like light rubbing sound? or its loud?
Old May 16, 2008 | 01:12 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Where is it rubbing... take your wheels off and look... and come back and post...
Old May 16, 2008 | 01:16 PM
IP37's Avatar
IP37
yea.. and check for rubber missing on your tires
Old May 16, 2008 | 01:58 PM
Kidcane's Avatar
Kidcane
Florida G Club
You can also go with stiffer springs or even coils and maybe add sways. That will minimize the travel distance and reduce rubbing.
Old May 17, 2008 | 04:32 AM
johng35m's Avatar
johng35m
im telling you where its rubbing. that metal bracket
Old May 17, 2008 | 08:40 AM
IP37's Avatar
IP37
either trim is some more, dial in some more camber, get a thinner or different tire, or change offset
we still don't know how much it's rubbing, so we don't know how much you need to change. i'd guess that a 275 would fix it though
Old May 17, 2008 | 12:16 PM
The1andOnly's Avatar
The1andOnly
+1 on changing to 275. That should've been your first try before trimming today the meatal bracket. If changing tires doesn't work, than you're most likely gonna have to change offsets.
I can't believe they didn't give you offsest though. Did you check the wheel itself for any markings for the offsets?
Old May 17, 2008 | 01:26 PM
symalik's Avatar
symalik
yea when IForged doesn't release offsets, they usually guarantee fitments.
Old May 17, 2008 | 02:47 PM
bfranks's Avatar
bfranks
It would probably fit fine if the car wasn't lowered. There really is no reason for a company not to release offsets.
