HELP Fitment Question!
Old May 13, 2008 | 07:16 AM
G37nS2K's Avatar
G37nS2K
im not too smart when it comes to Proper wheel fitment on cars
19 9.5 +17 front 19 10.5 +18 rear
will these fit on the G37S?
will these clear the big brakes?
according to my quick research the offset should be bigger than +30 is this correct?
specific answers desired
thank you in advance
Old May 13, 2008 | 09:36 AM
Kidcane's Avatar
Kidcane
Florida G Club
Cant reall say on the brakes clearing but the offsets are going to be a little too aggressive for the 37. Your wheels will definitely stick out. Yes with those size wheels +30 is about as low as you can go.
Old May 15, 2008 | 12:59 AM
symalik's Avatar
symalik
Those will not fit, they will stick out about a little more then 1/2 an inch... but should clear the brakes I would think.
Old May 15, 2008 | 02:46 AM
TerribleONE453's Avatar
TerribleONE453
yea i think they will be fine on the brakes but will be way to aggressive....
Old May 15, 2008 | 05:25 PM
sharif@forged's Avatar
sharif@forged
+2
That is an aggressive 350/G35 offset, so would be super duper not usable on the G37C.
Stick to mid 30's for solid fitments.
Old May 15, 2008 | 05:43 PM
gan78mao's Avatar
gan78mao
do it!!
super aggressive!!
im at +15 all around!!!!
Old May 15, 2008 | 06:40 PM
sharif@forged
Originally Posted by gan78mao
do it!!
super aggressive!!
pics...please? Did you go widebody?
Old May 15, 2008 | 06:45 PM
gan78mao's Avatar
gan78mao
nope! the front came in perfectly after the drop
the rear i pulled the fenders a tiny bit
the drop helped alot!
https://www.myg37.com/forums/picture-share-g-coupe/175190-finally-done-for-a-while-rims-are-back-on.html
theres a rearshot!
Old May 15, 2008 | 06:49 PM
GiGGaplease's Avatar
GiGGaplease
aggressive is good. do not like it tucked in the fenderz. i like it more flush.
Old May 15, 2008 | 06:52 PM
GiGGaplease
its going to stick out more than 1/2, i have 9.5 +30 10.5 +30, and it sticks out a little around 1/2
Old May 15, 2008 | 08:30 PM
TerribleONE453
if you dont mind pulling your fenders... go for it
Old May 16, 2008 | 01:52 AM
symalik's Avatar
symalik
yea, but if you don't have to do it... its not worth the trouble IMO
Old May 16, 2008 | 03:24 AM
CrazyRuskie's Avatar
CrazyRuskie
Crazy Russian Super Mod
Those won't fit.
As for brake clearance, you can't know if they will clear brakes regardless of size or offset. The wheel design is where you will know, it all depends how the spokes are designed.
Old May 17, 2008 | 09:46 PM
G37nS2K's Avatar
G37nS2K
thanks for all your informations
this offset is originally for G35/350z
should i take it as most of the aftermarket wheels for G/Z will not fit on G37?
Old May 17, 2008 | 09:55 PM
GiGGaplease
that is incorrect and correct at the same time. i brought rims for my 37 that was meant for the 35. the rear fit but i needed spacers for the fronts. wait, i have no clue what i am talking about. spacers will make any thing fit.
