Question about our Offsets
Old Apr 16, 2008 | 01:44 PM
Wicked_limitz's Avatar
Wicked_limitz
hey guys, looking at a couple sets of wheels right now and have a few questions
first set are Volk GT-V's
19x9.5 and 10.5 Offsets on this set are +24 front, +30 rear
second set are 20" gold Sevas s22 front: 8.5x20 et +20 rear: 10x20 et +20
i really dont want to purchase any of them if they wont fit, can anyone give me some answers?
Old Apr 16, 2008 | 04:59 PM
maxipad96's Avatar
maxipad96
No and no. Try again.
Old Apr 16, 2008 | 05:20 PM
symalik's Avatar
symalik
The rear for the volks might fit, will be close but the front will not fit.
2nd set will definitely not fit.
With Seva's people usually get the +40 offset option and use spacers to make them fit flush.
Old Apr 16, 2008 | 05:55 PM
GiGGaplease's Avatar
GiGGaplease
why wouldnt the volks fit? i have 19 9.5+55 and had 25mm spacers so their basically +30 right now and it only sticks out about less than 1/2 inch.
Old Apr 17, 2008 | 12:26 PM
symalik's Avatar
symalik
yea and a +24 will stick out more then half an inch, which is alot, unless the OP wants to pull the fenders and run a lot of camber up front.
The +24 is a G35 offset and sticks out quite a bit on a G37 (some one posted pictures few months ago I think), I have 9.5 +35 in the front and they barely tuck in. if your +30 sticks out meaning a +24 would stick out even more, which I thought means that it doesn't fit.
You can use a 20mm spacer instead of +25 and you should be pretty flush, maybe even a 15mm spacer.
If sticking out is fine, then really anything should fit... just doesn't look normal.
Old Apr 17, 2008 | 12:35 PM
Kidcane's Avatar
Kidcane
Florida G Club
Really I think you could get either to just barely fit with some work. May stick out a few MM but thats it with some camber dialed in.
Old Apr 17, 2008 | 01:25 PM
symalik's Avatar
symalik
I guess I wouldn't buy a set like that with out first trying them on the car. But thats just me.
Old Apr 17, 2008 | 01:33 PM
maxipad96's Avatar
maxipad96
There are pictures floating around of the S-22 in that offset. It does not look good. Not even close in the rear.
The GT-V just isn't optimal sizing for the G37.
Old Apr 17, 2008 | 02:39 PM
GiGGaplease
yes its not but if you like your tires to stick out about 1/2 inches all around, they would fit. my rears are 10.5 +30 and they only sit out around 1/2. its not too bad, i thought it would stick out like an inch or something. if you like the wheels, just get it, sure they will stick out, but who would look at the sticking out ness if your car is moving with flames coming out from the exhaust?
Old Apr 17, 2008 | 02:49 PM
GiGGaplease
double posting without my content is ftl. ehhh
Old Apr 17, 2008 | 04:08 PM
maxipad96's Avatar
maxipad96
I like wheels to be at the fender line as well, but the Sevas are too far out IMO.
found the pic of the sevas +25 rear.
Old Apr 17, 2008 | 06:08 PM
symalik's Avatar
symalik
This is what a little less then 3/4 of an inch looks like sticking out with no camber.
Old Apr 17, 2008 | 10:38 PM
maxipad96's Avatar
maxipad96
Attachment 78151
Wow. That looks awful. Thanks for the pic. What are the specs on that?
Old Apr 18, 2008 | 12:45 AM
Wicked_limitz
here are the wheels i was talking about....
http://g35nyc.com/forums/showthread.php?t=7512
Old Apr 18, 2008 | 02:20 AM
symalik's Avatar
symalik
or this https://www.myg37.com/forums/picture-share-g-coupe/174958-couple-pics-of-my-car-on-dpe-wheels-and-side-by-side-with-g35.html
I guess not to bad.
Raleclair
Oct 8, 2015 02:06 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
nomorecivicsi
Sep 10, 2015 03:58 PM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
Simran Mann
Sep 9, 2015 02:08 AM
