Widest tire for rear
Old 02-28-2008, 04:32 PM
chilibowl
chilibowl's Avatar
Wider tires do not cause a bigger wheel gap.
Technically, the widest tire you could put on a 8.5 inch rim is 275, but the safer alternative would be a 265.
Technically, the widest tire you could put on a 9 inch rim is 285, but the safer alternative would be a 275.
Putting a 275 on the front rims would be stupid IMO. The largest you should go on a 8.5 inch front rim is 245.
Old 02-28-2008, 05:56 PM
shumby
shumby's Avatar
Nerrow up front wide on the back is the style I am looking for. Mostly want the wider rear for looks. The gap is a non issue if you keep your profile right it will look the same. Now what do you guys mean about the rim sticking out?. I know I don't want the tire to stick out past the fender. I just want the widest with out have it go past the fenders and stay on stock rims.
Old 02-28-2008, 07:55 PM
Catt
Catt's Avatar
Originally Posted by Darkvader
The G37 fenders are rolled already. With 305/25/20 you will more than fine. U will have a 3.5 inc visible lip and a total of 4.2 inc lip.
interesting, I didn't know they are rolled. That makes things easier.
Old 02-28-2008, 10:50 PM
TerribleONE453
TerribleONE453's Avatar
Yea 305 in the rear should be fine..
Old 02-28-2008, 10:55 PM
Gwhiz37
Gwhiz37's Avatar
From a previous post:
Put 275/35ZR-19s on original rear wheels
Thanks to those that helped when I was looking for a wider, more all season tire for the varied NC weather. Looked at many, settled with the Michelin Pilot Sport A/S for about $340 a tire. The grip is incredible and I do not feel in hard cornering as if the tire will fold. The look, as you can tell from the attached pixs, is great. Yeah I know I should have put 4 on now, but, hey, you can only do so much so quick.
I do notice a slight lowering in MPG. The speedometer is pretty true, only off by .4 MPH at 60 MPH.
This is the widest tire you can place on the rims. Believe me, I tried from every angle to go wider, but kept safety in mind.
Look at these pixs:
https://www.myg37.com/forums/attachm...9&d=1201362177
https://www.myg37.com/forums/attachm...0&d=1201362257
Old 02-28-2008, 11:18 PM
shumby
shumby's Avatar
Cool good to know I get 66.6% off list on Michlins so once the summer were off on go the pilots. I run pilot apins now on both my maxima and G37. Pilot sports on the maxima in the summer. Thanks for that info.
Anyone do 305 on the rear and got pics?
Old 02-29-2008, 12:40 PM
lowrider
lowrider's Avatar
Keep the OEM Tire and model. Put the current rears (245/40/19) on the front and put 275/35/19 on the back. This will maintain the correct tire heights, give you wider tires all around, improve your handling, and give you the wide tire look you are looking for. It will also reduce your out of pocket expenses because you are only buying two new tires.
Lou
Old 03-03-2008, 12:25 PM
Darkvader
Darkvader's Avatar
Hey ChiliBowl. No one cares about the safety issues here. So next time pls read or stay WPB. lol
Old 03-05-2008, 01:29 AM
UNV-IT46
UNV-IT46's Avatar
275 is the widest i can run because of the drop
Mattlorentzoe
05-24-2021 08:49 PM
lobuzz311
16
10-17-2016 08:59 PM
ddayeg37s
08-09-2015 07:10 PM
Quick Reply: Widest tire for rear
