rim fitment FAQ?
Old Dec 28, 2007 | 01:36 PM
jdm_inspire's Avatar
jdm_inspire
rim fitment FAQ?
Hi there,
May I suggest someone 'sticky' a thread discussing what rims will fit or not fit? That way, this will end some of the redundancy about "will this fit?" threads will occur.
First, could someone post OEM specs for the 18" and 19" rim packages along with the corresponding tire sizes. From there, those of us who know how tires and rims are measured, can make educated guesses on what will / will not fit.
Thanks!
For example:
OEM 19" rims:
19x8.5 (+ 43 offset) with 225/45/19 tires for the front
19x9.0 (+ 45 offset) with 245/40/19 tires for the rear
OEM 18" rims:
18x8.0 (+ __ offset) with 225/50/18 tires for front & back
Then can someone say for wider rims, what would be the recommended width/offset combination that can be safely done without having to do any fender mods (ie roller fenders, need to run negative camber), etc? That would be great!!!
Last edited by jdm_inspire; Jan 2, 2008 at 04:51 PM. Reason: updated offset as per uclabruin
Old Dec 28, 2007 | 02:20 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
^^^^great idea... you shouldve posted this in the feedback section tho...
I think there needs to be more stickys with FAQ and How-to's Also...
Sticky info is great and it would be able to eliminate newbie threads...
Old Dec 28, 2007 | 02:51 PM
GiGGaplease's Avatar
GiGGaplease
Old Dec 28, 2007 | 03:09 PM
solopresident's Avatar
solopresident
everyone needs 20's!
Old Dec 28, 2007 | 03:33 PM
RYs06MT's Avatar
RYs06MT
+1 for dubs.
Old Dec 28, 2007 | 04:48 PM
ucla bruin's Avatar
ucla bruin
Good idea.
__________________
Old Dec 31, 2007 | 04:45 AM
ucla bruin's Avatar
ucla bruin
From G37-tech.com:
The ten spokes of the 19" wheels incorporate a beveled twist to make the light dance as they spin, creating a sense of surprise and visual appeal. yet ultimately they're created to perform. Low weight, and large size to put more tire on the road, heightens responsiveness and control. Front:
* Weight: xx lbs
* Size: 19 X 8-1/2J
* Material: Aluminum
* Offset: 43 mm
* Tire Size: 225/45WR19
Rear:
* Weight: xx lbs
* Size: 19 X 9J
* Offset: 45 mm
* Tire Size: 245/40WR19
__________________
Old Jan 2, 2008 | 04:52 PM
jdm_inspire
My bad. And thanks ucla_bruin for adding that info. I updated my original post. Now I can begin hunting for rims that will fit the 13" brakes / calipers ...
Old Jan 2, 2008 | 05:01 PM
MaxToTheG37
your straight... I would love to know info like you said also... example... What offsets are needed... what width is too wide... what dont fit... etc...
Maybe in a few days we can have a nice sticky ready to stick lol
Old Jan 2, 2008 | 07:28 PM
terrycs's Avatar
terrycs
Anyone want to maintain one of these for the G37?
http://g35driver.com/forums/showthread.php?t=159247
If so, let me know and I can email you the template.
Old Jan 27, 2009 | 10:53 PM
mixturepinoy's Avatar
mixturepinoy
LMEFO!!!
bump for sticky
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Soccer4555
Sep 30, 2015 05:31 PM
pal51961
Sep 27, 2015 08:38 PM
