My tirerack.com pricing..
Old Nov 26, 2007 | 03:43 PM
go4gr8's Avatar
go4gr8
Lightbulb
Looks great!
This is a great how-to.
May I also suggest putting on some anti-seize compound on the wheels (where the wheel contacts the hub) before bolting in the wheel? This will prevent wheels from seizing onto the hub after the harsh winter.
Old Nov 26, 2007 | 03:54 PM
shumby's Avatar
shumby
^^ Kopper Kote is goot for that.
Old Aug 13, 2008 | 02:49 PM
heff's Avatar
heff
can u get blizaks for our stock rims?
Old Aug 13, 2008 | 03:16 PM
UNV-IT46's Avatar
UNV-IT46
on a side note. that little bolt that you removed from the rotor assembly does not need to be reinstalled. it must be removed to put pretty much all after market wheels on the car. i was told its for use during assembly of the car but nothing after the car is done being built
Old Aug 13, 2008 | 08:51 PM
TheCutter's Avatar
TheCutter
Yes, LM-25's. At least, according to Tirerack.
Old Oct 13, 2008 | 05:46 PM
vINCe_Inc's Avatar
vINCe_Inc
Originally Posted by Orbie
I think the Sport Edition A7's that some of us went with for $99 are a knock off of those ASA ones, as they look almost identical. Anyways, did you receive centering rings with those? I'm just curious what the size was on those rings. When mounting my winters I noticed that the centering ring did not fit perfectly on the car hub. I bolted the rims on thinking it would force the rings on the hub, but it just appears to have pushed the rings on as much as possible, I still don't think they are flush. I'm hoping they didn't send me one size to small.
Anyone mounting the ASA's or A7's want to chime in?
Also did anyone notice that the offset on these rims push the rim out? I actually like the look of the wheels pushed out further, I wish that was the case with the summers. Much more aggressive filled out look, too bad the rims don't look anywhere near as good as O.E. 19's.
yea, seem like the ones i saw on tirerack are knock-offs.
i managed not to go with tirerack and bought local.
rk325
Oct 13, 2015 01:51 PM
onthefence
Dec 10, 2013 11:06 AM
Loki123
Canada
17
Jan 29, 2013 09:39 AM
demarco5
Feb 9, 2011 11:07 AM
