Tire Size
Old Sep 17, 2007 | 04:43 PM
Sweeet P's Avatar
Sweeet P
Tire Size
Maybe a dumb question, but can any of you help me understand the reasoning behind the different tire sizes on the G37 Sport Model vs the Journey model. I'm assuming it's better performance-wise.....but I wanted to get insight as to how this affects tread wear/tire rotations. Also, if you replace the tires or get aftermarket rims in the future, can you get all the same size? I'm clueless...please educate.
Old Sep 17, 2007 | 05:13 PM
Callaway's Avatar
Callaway
Arm flailing tube man
The Sport model or the Journey with the Sport package comes with 19" rims instead of 18". Hence, the different tire sizes. I think they went with the larger 19" because the Sport models also include 14" brake rotors in the front and 13.8" in the back. The base model and Journey model without Sport package comes with 13" rotors so 18" rims fit. The G coupes come with a staggered setup which means the tires in the rear are wider than the ones in the front. You can't rotate them like you can on traditional cars. If you get aftermarket rims, you would want to make sure they are staggered as well whether you go the same diameter or larger. Hope this helps.
Old Sep 17, 2007 | 06:56 PM
I have a Maxima with staggered wheels from a 350Z. OE tire sizes are 225 (7" wide wheel) front/245 (8" wide wheel) rear, making rotation impossible. However, I put the same size tires on all 4 wheels (235). I can rotate tires now, but I must break down each wheel and actually have the tires swapped onto the proper wheels before replacing them on the car. Is there a point in having wider rear tires on a FWD car? Absolutely not from a practical standpoint. But I like the way they look on the car and it does corner better. If you get aftermarket wheels that will fit the G37, you could consider getting all 4 the same width so that you could rotate them normally and save a lot of money on tires.
Old Sep 17, 2007 | 07:23 PM
Callaway's Avatar
Callaway
^^you don't think doing that would mess with the driving dynamics of the car? I am wondering why Infiniti/Nissan does the staggered set up on these cars?
Old Sep 17, 2007 | 08:02 PM
spyderbret's Avatar
spyderbret
Would you be able to put even wider tires on the rims when it comes time for replacement?
Old Sep 17, 2007 | 08:31 PM
Most definately. It improved them dramatically. I also made various other upgrades such as springs, struts, rear anti roll bar, strut tower brace, etc. It corners like a dream now with no hint of FWD understeer.
Old Sep 17, 2007 | 09:41 PM
G35_Diva's Avatar
G35_Diva
Black Betty: That signature is the BEST!!!!! LOL!!
Old Sep 17, 2007 | 09:56 PM
It's all your fault.
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
