Special WORK Emotion XC8 *** Clearance Now *** 19x9.0 / 19x10.0
Ok, just got the go ahead from WORK wheels to announce these setup for clearance.
For G35/G37/370Z - 19x9.0 +20mm offset, 19x10.0 +20mm or offset - $1750.00 / Original Retail - $2200
color - Gold, Silver, Bronze
Alternative Options - 18x9.5 +20mm offset All Around - $1590.00 / Original Retail - $2000
NOTE: Pictures below are 18x9.5 20mm offset all around w/ concave look
Anything lower than a 10 +50mm rear, requires the fender liner to be trimmed.
10 +35mm will still fit without modifying the the actual fender.
The +20mm> 15mm more aggressive (.59") will require a negative camber and a slightly stretched tire, and a slight fender pull depending on tire width.
This is based on a locals car who we test fit the 50, 40 and 35mm
Front has almost as much room as the g35, so not difficult to fit the 9+20mm.
Thank you, Rick G.
Thank you, Rick G.
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
New2Infinity
Sep 9, 2015 10:34 AM
