Lightwerkz
Old Sep 15, 2016 | 09:24 AM
ShuuraRG's Avatar
ShuuraRG
Lightwerkz
I figured that this may be helpful to someone looking to mod their heads. I took me 2 years before I finally modded mine, and the tip about not painting the chrome reflector piece is golden!
Old Sep 15, 2016 | 09:14 PM
saywat?'s Avatar
saywat?
id prefer painting the chrome. why would u want it stick out and look like eye *****?
Old Sep 16, 2016 | 06:31 AM
ShuuraRG's Avatar
ShuuraRG
Doing so would result in the paint bubbling over that spot. You'd either end up constantly repainting that spot, or ignoring it to be explained when people see it and ask why.
Old Sep 16, 2016 | 11:47 AM
saywat?'s Avatar
saywat?
U sure? That's a common thing on g37s? Bc I painted my g35 projectors and had no issues like that. I didn't even use primer I jus used the paint and primer type spray can
Old Sep 16, 2016 | 11:50 AM
ShuuraRG's Avatar
ShuuraRG
I guess it depends on if we're talking about the same chrome piece. I was referring to the reflector strip just below the project.
Are you referring to the shroud around the projector?
Old Sep 16, 2016 | 01:04 PM
saywat?'s Avatar
saywat?
I'm referring to shroud and every part thats chrome that's paintable. So Wats bubbling from? Can't be from heat from the lights bc on my g35 I used the fogs as driving lights at night no issues. The g37 are basically the same
Old Sep 17, 2016 | 09:15 AM
ShuuraRG's Avatar
ShuuraRG
Painting the shroud is fine, but the chrome reflector below the projector will bubble if you paint over it. The headlight isn't the cause, but the sun is! There are a few members here who've done so and can attest to the results.
Old Sep 17, 2016 | 01:43 PM
saywat?'s Avatar
saywat?
Idk man the sun? U sure they jus didn't sand the area down enough before paint
Old Sep 17, 2016 | 01:55 PM
bigmike35nj's Avatar
bigmike35nj
I'm a victim of painting over that piece. And for sure I have bubbles. It's gotten worse also. I'll take a pic. I also have the clear lens upgrade which is what makes it worse from the sun.
Old Sep 17, 2016 | 02:26 PM
saywat?'s Avatar
saywat?
So it engine paint enamel the solution? I will eventually do this mod and read up on wat info is out there before hand
Old Sep 17, 2016 | 02:34 PM
saywat?'s Avatar
saywat?
Maybe ill leave a strip chrome below the projector too like the vid.
OBG37
Apr 15, 2026 01:06 PM
2011-G
Intake and Exhaust
Oct 5, 2016 10:32 PM
Tukeeg35
Sep 19, 2016 05:59 PM
Troy Johnson
Intake and Exhaust
Sep 14, 2016 11:09 AM
Daddy Fat Sacs
Sep 11, 2016 01:29 AM
