TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
ITB07-007a TAPPING NOISE FROM DASH AREA
Old May 25, 2008 | 10:16 AM
chinua's Avatar
chinua
ITB07-007b TAPPING NOISE FROM DASH AREA
APPLIED VEHICLES:
2008 G37 Coupe (CV36)
APPLIED VINS:
G37 Coupe built before JNKCV64E(*)8M 125916
APPLIED DATES:
2008 G37 / G35 built before: 03-Apr-2008
A tapping noise coming from the dash area when the engine is running at operating temperature,
NOTE: This tapping noise, if it should occur, sounds like a screwdriver being tapped on the work bench.
The tapping speed increases and decrease with the engine RPM and may require engine RPM of about
3000 for the noise to be heard.
File Type: pdf
Last edited by chinua; Jun 8, 2008 at 10:09 AM. Reason: Added June 3, 2008 update (b) which address Primary Part (PP) type line specific for G37
Old May 25, 2008 | 10:20 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
this is for you blackjack...
Old May 25, 2008 | 10:43 AM
GiGGaplease's Avatar
GiGGaplease
i sometimes get this noise, but not often though...guess its the heat that is causing the problem.
Old May 30, 2008 | 03:48 PM
Ahujadaddy's Avatar
Ahujadaddy
hmmm, cd this be the infamous center dash rattle!? do i not hear it anymore cuz im using the COOL AC now instead of heat?
It got really bad towards the end of winter into early spring. I thought maybe just the fluctuation in outside temps
Old May 30, 2008 | 04:23 PM
Kidcane's Avatar
Kidcane
Florida G Club
My car falls in that vin range but I have never heard the noise. Is it only when the heat is on cause I have not run my heat yet. Living in Tampa its rare that I do.
Old May 30, 2008 | 04:24 PM
finagle69's Avatar
finagle69
I swear I've heard this noise before, but not recently. Probably ambient temp related?
Anyway, thanks for posting this. It'll go in the file.
Old May 30, 2008 | 05:16 PM
Blackjack's Avatar
Blackjack
Finally!!! Thanks Chinua!
Old May 30, 2008 | 06:23 PM
shumby's Avatar
shumby
Just got the noise today drove to the dealer made apointment to get fix. Made mechanic come out and hear it as these noises tend to come and go. Good thing drove it home and it stopped.
Old May 30, 2008 | 06:52 PM
MrMichael's Avatar
MrMichael
Oh wow, I had this noise 3 months ago and took it in because of it but of course it didn't show itself at that time and the dealer seems to think I'm imagining things when it doesn't happen when I'm there.. I will definitely be having them look at this again.
Old May 31, 2008 | 12:37 AM
wrathletik1's Avatar
wrathletik1
So what do they do to fix this?
Old May 31, 2008 | 01:08 AM
finagle69's Avatar
finagle69
Download and read the attached PDF in the first post. It - just like all TSB's - describe how to detect and remedy the problem.
Old May 31, 2008 | 07:43 PM
ReddieG37's Avatar
ReddieG37
I get tapping noise from my dashboard if my car has been sitting in the sun for a while. Does this for like 30 seconds and goes away... probably temperature related. Is this the same tapping noise for the TSB?
Old May 31, 2008 | 09:38 PM
SOLISIMO's Avatar
SOLISIMO
I had this tapping noise from my dash, after further investigating, I found two Mexicans under my dash
Old Jun 7, 2008 | 02:19 PM
chinua's Avatar
chinua
Old Sep 12, 2008 | 01:57 AM
shabbo's Avatar
shabbo
Dealer thought I was imagining this too..LoL It was in the winter time when I actually used the heater.
