The M - Spot General discussion for the M35/M45
Drop in filters
Old Mar 10, 2020 | 11:08 AM
Carlos Martinez's Avatar
Carlos Martinez
Drop in filters
I bought some R2Cs from a member and they don’t fit. I got them since I figured that most things that for a G would work. Any ideas or should I just sell them?
Old Mar 11, 2020 | 03:05 AM
Said Amir's Avatar
Said Amir
I have K&N drop air filter and at first they are a tight squeeze and you need to force it to close, but now I can take it out and place it back in with ease. Aftermarket drop in filters at time have just a small amount of more side rubbers just to not have any crap go into the engine.
Old Mar 11, 2020 | 11:08 AM
Carlos Martinez
I’m not sure I can. I bought them not realizing that they’re for the Z/G only. Apparently there’s a different design for the M. I’ll resell them instead of risking it
Old Mar 11, 2020 | 11:29 AM
Said Amir's Avatar
Said Amir
Oh I did not know you had a M, yeah I don’t know much on it. Yeah just sale it if anything.
Old Mar 12, 2020 | 06:42 AM
Carlos Martinez
So far I’ve only found K&N and AEM for M37s. I Was thinking of getting a Tekada ram, but I don’t want to waste money atm
Old Mar 13, 2020 | 08:52 PM
Joyryde's Avatar
Joyryde
Interesting, it should have fit since the components are pretty much identical to the G37 engine bay, including the filter boxes. I know the M56 has a different style air filter system similar to that of the Q50 3.0t variant.
Old Mar 13, 2020 | 11:08 PM
Carlos Martinez
I would have to rig it by taking the OEM filter element apart and somehow attaching the R2C on it.
Old Apr 16, 2020 | 08:07 AM
telcoman's Avatar
telcoman
I only use filters that I purchase at the dealer parts department for my Q70 and they fit perfectly. I change them every ten thousand miles
Old Apr 16, 2020 | 10:28 AM
BULL's Avatar
BULL
Moderador
You could try to hollow the factory element to see if you can turn the factory filter into a bracket that will hold the G37 element.
That's great information that you are providing telcoman. I dont mean any disrespect however your comment is useless and does not contribute anything to this thread. OEM filters fit perfectly because that is how the world works and we're glad you change them every 10k.
Though they share the same engine the boxes differ. The M uses the radiator cover/shroud to feed air into the boxes and the G37 has holes in the radiator support for direct air channeling. Pictures of the boxes and filters are different.
Old May 6, 2020 | 07:02 PM
Joyryde's Avatar
Joyryde
Well I had no idea. I just googled "M37 Engine bay" and it seems that they showed the G37 engine bay instead. I prefer the G37 air boxes more than the stupid radiator shroud I have to deal with. Seems Q50s also have that shroud.
Old May 23, 2020 | 06:49 PM
CRV_33's Avatar
CRV_33
Carlos, if the intake system came off an M37, it will fit with some minor modifications. In fact someone posted a tutorial on how to install it on an M37:
https://www.myg37.com/forums/the-m-s...installed.html
Old May 28, 2020 | 01:47 AM
Joyryde's Avatar
Joyryde
Do any M owners drive around without the shroud on? I'd imagine it wouldn't cause no harm and increase air flow since the shroud tunnels are extremely restrictive.
bat6wc
Aug 31, 2012 12:39 PM
maxipad96
Jan 29, 2011 04:59 PM
Exige
Nov 23, 2010 12:27 PM
cvt
Intake and Exhaust
22
Jun 10, 2008 01:23 PM
