The M - Spot General discussion for the M35/M45
Headers & Exhaust Question
Old Feb 18, 2014 | 03:46 AM
stm37s's Avatar
stm37s
Has anyone ever had their warranty voided because of these two mods added to their ride? just asking. Thanks for the feed back fellas
Old Feb 18, 2014 | 01:53 PM
poktang35's Avatar
poktang35
If you need to do some dealership warranty work a lot of people go in stock. They might blame your mods for problems even if it's a total lie. Although exhaust should be fine as long as it's a cat back.
Old Feb 18, 2014 | 10:19 PM
RISKY GUY's Avatar
RISKY GUY
If he is doing just a cat back, yea you could swap back before going to the dealer.
The op mentioned headers, that is a major job & is not an easy swap.
You need a lift & I'd say at least 6-8 hrs, there is no short cut doing headers on the g.
No room, could barley fit my hand between steering knuckle & bottom of header on d/s.
Old Feb 19, 2014 | 02:29 AM
G37Sam's Avatar
G37Sam
Dealerships will look for the lamest excuse to void your warranty. A catback is less involving in terms of install and risk factor. Headers bolt to the Engine Head directly meaning the dealer will have a much better case to screw you if something was to go wrong with the engine.
If the dealership is mod friendly and are willing to install them for you, that's a different story. I'm sure their labor charges will leave a hole in your wallet though.
Off topic: Headers are a waste of money and not worth the ROI (parts and laborwise) in my honest opinion. A catback and some resonated test pipes is as far as I'd go.
Old Feb 19, 2014 | 07:49 AM
RISKY GUY's Avatar
RISKY GUY
Sam, headers are not a waste of money. That's just your opinion, you seem to have long tube headers before your motor swap.
Are there other mods that can be done for less of course.
The factory headers flow like crap, have you seen the inside of the stock header.?
Plus with the aftermarket header, you can use a dremel to smooth out any rough spots.
Wish I took pictures of the inside of the stock header. It's made like crap.
Bottom end much more responsive & top end was day & night.
I stand corrected, unless they are Fast Intention long tube headers they don't work.
Old Feb 19, 2014 | 11:21 AM
stm37s's Avatar
stm37s
Thanks for the response fellas, I have an extended warranty on my m37 and was wondering about getting these mods done, I would be getting the cat back from stillen and some headers along with high flow cats and a air filter kit and last but not least a tune. Just trying to gather all the information and take it from there. I know the stock headers are very restrictive along with the factory exhaust, just trying to free up as much horsepower as I can. If you have anymore ideas please share them.
Old Feb 19, 2014 | 03:23 PM
G37Sam's Avatar
G37Sam
Explain to me how a $2000 investment, 1 day downtime and warranty voidance risk for a few horses gained over test pipes is worth it
Old Feb 20, 2014 | 01:09 AM
stm37s's Avatar
stm37s
Thanks for the info G37Sam and RISKY GUY, I do want some added power but not at the cost of losing my warranty. The cat back and air filter kit is probably what I will stick with. This is what forum talk is about, giving good advice and pointing people in the right direction so they can make the best choice for them.
Old Feb 20, 2014 | 03:04 AM
stm37s's Avatar
stm37s
Hey fellas, I was able to find my extended warranty coverage and kind of confused. I don't see anything pertaining to aftermarket exhaust and headers and so forth or unless I'm reading this wrong, best guess, is that I will just have to call to get a better understanding. I wanna do the mods but not gonna risk the warranty as stated earlier, let me know what you all think, thanks fellas
Coverage Details
Drive Axle Assembly
Final drive and axle housings and all internally lubricated parts, flex disc, axle shafts and bearings, universal and constant velocity joints, drive shaft, center bearings and drive shaft yokes.
Engine Assembly
Cylinder block, cylinder heads, rotor housings and all internally lubricated parts, intake manifold, exhaust manifolds, timing gears, time chains or belts, timing chain or belt tensioners and timing chain or belt cover, valve covers, flywheel or flex plate, ring gear, harmonic balancer, oil pump, fuel pump, vacuum pump, water pump, oil pan, thermostat, turbocharger or supercharger housings and their internal parts, waste gate, intercooler and engine mounts.
Transmission Assembly
Transmission case, transaxle case, transfer case and all internally lubricated parts, torque converter, vacuum modulator, cooler and metal cooler lines and transmission mounts.
ABS Brakes
ABS booster/pump, master cylinder, solenoids, control processor and sensors.
Advanced Technology Package
Electronic Suspension — Variable suspension struts, switches, air tubes, control processor and sensors, air suspension bags, compressor, lines and fittings. Four-Wheel Steering – Steering pump, gear housing or rack assembly and all internally lubricated parts, power cylinder, center shaft, stepper motor and control processor and sensors. Traction Control — Linkage, solenoids and control processor and sensors. Memory Seat and Steering Wheel — Activator switches, motors, solenoids and control processor and sensors.
Air Conditioning and Heating Assembly
Belt-driven air conditioning compressor, clutch and coil, pulley, compressor mounting bracket, idler pulley and bearing and its mounting bracket, serpentine belt tensioners and its pulley and bearing, condenser, evaporator, accumulator, dryer, expansion valve, orifice tube, heater core, heater control valve, blower motor, control cables, ducts and plenum doors.
Braking Assembly
Master cylinder, wheel cylinder, calipers and their seals, power booster, accumulator, combination valve, backing plate assembly, metal brake lines and fittings, brake pedal and parking brake assemblies.
Engine Cooling Assembly
Fan, clutch and shroud, thermostat, radiator and its brackets and recovery tank, and electric fan motor.
Consequential Loss Coverage
This includes Consequential Loss Coverage, which is defined by the following two statements (as an exception to the standard exclusion): Non-covered Part Cause of Loss: In the event a breakdown occurs on a covered part under the Service Agreement due to the failure of a non-covered part, the covered part will be repaired. Covered Part Cause of Loss: In the event a breakdown occurs on a non-covered part under the Service Agreement due to the failure of a covered part, the non-covered part will be repaired.
Convenience Accessories
Power window motor, power seat motor and regulator, power lock motor and its relays and actuator, power mirror motors, power headlamp motor, power trunk and tailgate motor and solenoids, power side door motor, power top or sunroof motor, power antenna motor, horn and horn relay, rear window defogger/defroster, and side view mirror defogger.
Electrical Assembly
Alternator, pulley and mounting bracket, voltage regulator, starter motor and its solenoid and drive, wiper motors, manually operated switches, neutral safety switch, backup light switch and brake light switch.
Fuel Delivery System
Fuel injectors, injection pump, distribution rails, fuel pressure regulator, fuel tank and metal or plastic fuel lines and fittings, fuel level sending unit, throttle body, throttle cable, throttle linkage and accelerator pedal.
Hybrid Electrical Vehicle (HEV)
Electric motor, power controller, hybrid transaxle, electronic transmission, inverter, generators and electronic display monitor.
Interior Electronics
Electronic climate control head, digital dash display, heads-up display projector and control unit, trip/mileage/engine function computer, cruise control assembly, factory-installed entertainment system including radio, magnetic tape player, compact disc player and graphic equalizer.
Power Train Electronics
Ignition coil, distributor, timing control processor and sensors, fuel injectors, mixture control processor and sensors, IAC motor, cooling fan control processor and sensors. Electronically controlled transmission — Transmission shift control processor and sensors.
Seals and Gaskets
Seals and gaskets are covered for all listed parts, provided your vehicle had less than 100,000 miles at the time of the purchase of the agreement.
Steering Assembly
Steering gear housing, rack assembly, belt-driven pump and its reservoir and all internally lubricated parts, steering column shaft and its couplings and bearings, steering pump pulley and mounting bracket, pitman arm, idler arm, tie rods and steering linkages.
Suspension Assembly
Upper and lower control arms and their shafts and bushings, ball joints, steering knuckles and spindles, stabilizer and strut or track bars and their bushings and links, coil springs, torsion bars and their mounts, leaf springs and their shackles and bushings, hub bearings and wheel bearings and McPherson struts.
Vehicle Hardware Package
Bumper impact absorbers, headlamp mounting buckets, parking and side lamp bodies and sockets, hood latch and cables, hood hinges and springs, side door hinges, side door handles, glove box lock assembly, ash tray assembly, manual seat track assembly, courtesy light switches, trunk lid hinges and torsion bars, and trunk lid striker plate.
Additional Benefits
Substitute transportation, travel and lodging expenses.
24-hour Roadside Assistance
Battery jump service, emergency gas delivery service, flat tire change, key lockout service and towing and wrecker service.
Old Feb 20, 2014 | 10:24 AM
stm37s's Avatar
stm37s
well, just got finished speaking with a person from my extended warranty company and she informed me of headers, removing emissions controls items i.e. cat converter and over sized tires and some other minor items would void my warranty. So I guess I will be doing the exhaust and air filter kit
Old Feb 21, 2014 | 10:44 PM
RISKY GUY's Avatar
RISKY GUY
That's because you bought long tune headers.
Got shorty headers from stillen $550
Had my shop port & open them up even better $100
Labor for install $400. & a day.
That's less than I paid for just my fi cat back with HFCs.
Btw that was 10-20whp max for 1600 plus labor.
Old Feb 22, 2014 | 03:24 AM
stm37s's Avatar
stm37s
You did Risky Guy, I know you was happy with that price!!!!
chuckie311
78
Apr 18, 2016 08:56 PM
bkouba88
16
Aug 21, 2015 12:44 AM
MattCica
Intake and Exhaust
Aug 20, 2015 11:08 PM
reigle9
Aug 6, 2015 02:45 PM
