Supporting Vendors Products and services, available for purchase from registered vendors.
STRI Smoke Lens Stepping Motor Racing Gauges
Old Dec 6, 2008 | 11:48 AM
RAVSPEC's Avatar
RAVSPEC
DSD Series
STRI’s new DSD warning gauges offer all of the functions a demanding driver requires. Driven by rugged stepper motor, the DSD gauges inform you of your car’s vitals with extreme accuracy. Controlled by an advanced microprocessor, the DSD gauges are the latest in technology. Using the highest quality components DSD gauges will keep tabs on your car with surgical precision. . The DSD warning gauges are available in two sizes, 52mm and 60mm.
They are available in two models, the CS or the SLM series.
DSD Line FUNCTION
- Titanium Casing
- User Preset Warning
- Peak Recall
- Auto Self Calibration
- 270 Degree Sweep
- Short circuit auto detect
- Sequential open / closing mode
- Dimmer function
- High brightness LED
- Light weight aluminum casing.
- All sensors included
- Mounting solution included
- Available in smoke lens - black or white LED backlight
- Available in white face - Amber LED back light
- Available in black face - White LED back light
- Available in 52mm or 60mm size
Boost (2 bar) - $139.00 (electronic gauge)
PSI Unit
Boost (3 bar) - $159.00 (electronic gauge)
PSI Unit
EGT - $145.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $169.00 (electronic gauge)
PSI Unit
Oil Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $169.00 (electronic gauge)
PSI Unit
Water Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Tach - $99.00 (electronic gauge)
Voltmeter - $99.00 (electronic gauge)
Old Dec 6, 2008 | 12:20 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Thanks for posting deals here bruh...
Kojack
Oct 9, 2015 05:53 PM
ajosowiecky
Sep 30, 2015 12:15 PM
