Supporting Vendors Products and services, available for purchase from registered vendors.
HPAuto-Jwt Pop Chargers Nice & Cheap
Old Aug 21, 2008 | 09:28 AM
  #1231
sredish's Avatar
sredish
not trying to be a debbie downer at all.... i have one ordered so I'm obviously hoping for the best... but, you have to be careful with butt dynos. you can peak power the same hp but lose a little bottom and it'll feel like it gained on top to the butt dyno, so you walk away saying damn, i gained some up top but in reality you lost on bottom. not saying that's the case just kinda saying I hope this one proves out on the rollers.
Old Aug 21, 2008 | 03:50 PM
  #1232
SilverBullet's Avatar
SilverBullet
I just received my dual popchargers. However I am having some trouble with installing the heat shields. I can't seem to get them to fit. I can fit it around the the air inlet, but I can not get the radiator attachment to fit. I guess I am not good at installs.
Old Aug 21, 2008 | 04:12 PM
  #1233
weave's Avatar
weave
Before you install the shields into the car, put that "L" bracket on the shield but leave it loose. Now, install the shield and tighten the pinch clamp bolts all the way down. Loosen the bolt for the radiator support and slide the open end of the bracket under the bolt. Once that is in place, tighten the radiator bolt then go and tighten the nut/bolt on the shield.
Old Aug 21, 2008 | 06:33 PM
  #1234
kachinq's Avatar
kachinq
Originally Posted by bboysteele
Go to Autozone and get the code pulled so you know what it is for. You shouldn't be getting a SES light from your stock CATs with an aftermarket intake so get the code pulled so you know why the SES light went off and don't assume. You don't want it to be something bad and think it is a CEL light.
Thanks for the info. However im in hawaii and i dont think i have a autozone here...any other suggestions or places where i can pull codes? still giving me the CEL light...is it still safe to drive the car..?
Old Aug 21, 2008 | 06:44 PM
  #1235
Hawaiian72099's Avatar
Hawaiian72099
Hey bro not sure if some service stations like chevron will have the diagnostic tools for your car. Not sure if Checkers or Napa have test equipment as well.
Old Aug 21, 2008 | 09:40 PM
  #1236
LPG35's Avatar
LPG35
received and installed my intake today.
Old Aug 21, 2008 | 10:54 PM
  #1237
weave's Avatar
weave
Thanks. I figured it out. The driver's side was easy, passenger side was tough. The room is really tight and is touching just a bit, and I can not get the intake to rest as low as the driver's side. Is this a problem? I took it for a drive and I did not seem to have any problems. It sounds good!
I got both of mine at the same height by two methods.
1) I loosened the bolt where the factory filter goes on the fender and that allowed me to move some.
2) I literally pushed and bent the brackets the way I wanted them to get the filters to sit exactly the same on both sides. I am not talking about a lot of pressure but enough to accomplish the task.
Old Aug 22, 2008 | 01:04 AM
  #1238
kachinq's Avatar
kachinq
nvm after i reset it works fine =) thanks for all the info though
Old Aug 22, 2008 | 03:32 PM
  #1239
ufo's Avatar
ufo
recvd, not installed (yet)
Old Aug 22, 2008 | 04:08 PM
  #1240
0to60's Avatar
0to60
Got it...will install this weekend
Old Aug 22, 2008 | 10:14 PM
  #1241
floincali's Avatar
floincali
Received today, will install tomorrow...Thanks!
Old Aug 23, 2008 | 12:24 AM
  #1242
Skyline-LEXY's Avatar
Skyline-LEXY
wasnt it suppose to be 22 this week?
Old Aug 23, 2008 | 12:29 AM
  #1243
Hpauto's Avatar
Hpauto
They were delayed on shipping, 10 are leaving Monday to us. After this wave, they are shooting for 20 on next run. Its taking awhile but they are doing what they can, just hang tight everyone....soon enough
Old Aug 23, 2008 | 01:14 AM
  #1244
Skyline-LEXY
^^ thank for for your update Andy! GO HPA =]
Old Aug 23, 2008 | 01:26 AM
  #1245
ufo's Avatar
ufo
hey are the filter elements pre-oiled?? Mine do not appear to be, no big deal, just wonder if everyone knows.
