Help with using manual mode on auto transmission
I am going to be brutally honest... I have never driven a manual in my life. I have the 7 speed auto, but I don't feel like I shift properly in manual mode. Any help would be appreciated. I really struggle on downshifting too. I don't know if I show keep my foot on the gas when I downshift or what... Yeah, I'm lost, lol.
Any tips?
Any tips?
When down shifting have your foot off the gas, your engine will rev match for a smooth down shift. Timing and shifting at the right RPM takes a little practice and I prefer to use the gear shifter instead of the paddles for a quicker response time. I also lift my foot off the gas slightly when up shifting, again its all in the timing. IMO DS mode in my 5At is best suited for shifting between 2,3,4 on a curvy back road where you can open her up and keep on the power band just don't let the back end come around! Hope this helps!
when down shifting have your foot off the gas, your engine will rev match for a smooth down shift. Timing and shifting at the right rpm takes a little practice and i prefer to use the gear shifter instead of the paddles for a quicker response time. I also lift my foot off the gas slightly when up shifting, again its all in the timing. Imo ds mode in my 5at is best suited for shifting between 2,3,4 on a curvy back road where you can open her up and keep on the power band just don't let the back end come around! Hope this helps!
2cold i grew up driving a 1st Gen Rx7 so i was jacked up a little on any manual or sport mode shifting since then due to the rotary having higher reving engine. sometimes if im not paying close attention i tend to run the rpms higher than I probably should.
FlyIce
Sep 29, 2015 04:07 AM
LVASJR
Sep 14, 2015 07:37 AM
