2009 - G37s Journey Sports Coupe 74k Miles
Old 11-18-2022, 10:12 PM
kon17
kon17's Avatar
Year: 2009
Make: INFINITI
Model: G37 Coupe
Price: $16500
Mileage: 74000
Color: Black
Location (State/Prov): NY
Selling a 2009 G37 Coupe Journey (Sports) RWD in Black Obsidian - Clean Title, Tuned by AdminTune. Located in NYC. I'm the third owner, purchased the car with only 30k miles in 2018. Previous owner only drove the car ~2k miles annually. After I purchased the car I've only driven highway mileage. This is a garaged car, never parked in the streets overnight.
Recently did the Oil gallery gasket repair. It wasn't giving me any issues but just for a peace of mind decided to get it done.
Car comes with booklet manuals and 2 keys plus few other goodies listed below.
Looking for $16,500 or best offer. Reason for selling - I need a friendly daily for my work commute.
Defect:
  • I have the horn disconnected because I have some sort of relay issue going on when I was installing the LED Steering wheel. Whenever I connect the horn module the horn honks non-stop. I purchased a new ClockSpring that might fix the issue, just haven't had time to install so that will be included.
  • Hood is a little bent on the passenger side from an accident where my front grill got smashed and bent the hood a little with the impact. It's not noticeable unless you pay close attention to the it.
Below is a list of everything I've done so far:
  • Carbon fiber duck lip
  • Red Silicone Master Hose Set
  • Takeda Cold Air Intake Stage 2
  • Mishimoto Baffled Oil Catch Can System
  • Ground kit
  • Z1 Motorsports Brake Master Cylinder Brace
  • VIS RACING Carbon Fiber Grill
  • ISR Performance High Flow Cats
  • Flat bottom LED CF Wheel
  • LED headlight conversion
  • Diode Dynamics Tail-as-turn module
  • Dash Kit Vinyl wrap
  • Side mirror CF cover
  • IPL Rear Bumper
  • Illuminated kick plates
  • GTR-R35 Clear Map Light Lenses
  • KP Technologies Window Roll up Module (Not installed, but will be included - allows you to roll up the window with your keyfob)
  • KP Technologies Electronic Beep Module (Not installed, but will be included - this changes the horn sound when locking the door with your keyfob and instead does the beep)
  • Z1 2-Piece Akebono Front & Rear rotor (Installed 3 months ago ~4k miles usage)
  • EBC Brake Pads
  • Replaced Window surround weather strip
  • BC coilovers
  • GT-R Red Start button
  • Eibach Sway bar
  • Stainless Brake Line
  • OEMassive Headlights
  • QS Front Bumper W/ Fog lights
  • 10MM Wheel Studs
  • 5MM Spacer
  • Z1 VQ Performance Header
  • Z1 High Energy Ignition Coil
  • OEM GTR Spark Plugs
  • OEM Emission Canister replaced
  • Transmission Pan & Gasket changed less than a year ago
  • Replaced Alternator
  • Changed Serpent Belt & Pulley
  • Ceramic Tints: 5% all around (If you are not used to tints, highly recommend changing the front windshield tints to at least 20-35%)
Tune Map
Map 1: Race Mode
Map 2: Flame/Burble-Pop Mode
Map 3: Economic Mode
Map 4: Security (Shuts off engine)
Disclaimer: Vossen Wheels on the picture not included, car will come with stock wheels, can include picture at your request. If you'll like the Vossen wheels I can include it for an additional $1K - Tires still have 50-60% tread
I have pictures of when the car was stock and how it started to change over the years. I can add more pictures at your request on this link:
I have the lower mesh that goes on the front bumper. Is not installed on the pictures but I have it and will be included, just need to cut the mesh the size for the bumper.
Let me know if you have any questions.
kon17 is offline
tripled
08-23-2023 10:37 PM
Rogue_G
02-20-2020 08:00 PM
FSTG37
03-16-2017 10:19 PM
happyday0014
05-19-2015 04:28 AM
Status Elite
Picture Share G Coupe
09-18-2009 04:46 PM
Quick Reply: 2009 - G37s Journey Sports Coupe 74k Miles
