2009 - G37s Journey Sports Coupe 74k Miles
Year: 2009
Make: INFINITI
Model: G37 Coupe
Price: $16500
Mileage: 74000
Color: Black
Location (State/Prov): NY
Recently did the Oil gallery gasket repair. It wasn't giving me any issues but just for a peace of mind decided to get it done.
Car comes with booklet manuals and 2 keys plus few other goodies listed below.
Looking for $16,500 or best offer. Reason for selling - I need a friendly daily for my work commute.
Defect:
- I have the horn disconnected because I have some sort of relay issue going on when I was installing the LED Steering wheel. Whenever I connect the horn module the horn honks non-stop. I purchased a new ClockSpring that might fix the issue, just haven't had time to install so that will be included.
- Hood is a little bent on the passenger side from an accident where my front grill got smashed and bent the hood a little with the impact. It's not noticeable unless you pay close attention to the it.
- Carbon fiber duck lip
- Red Silicone Master Hose Set
- Takeda Cold Air Intake Stage 2
- Mishimoto Baffled Oil Catch Can System
- Ground kit
- Z1 Motorsports Brake Master Cylinder Brace
- VIS RACING Carbon Fiber Grill
- ISR Performance High Flow Cats
- Flat bottom LED CF Wheel
- LED headlight conversion
- Diode Dynamics Tail-as-turn module
- Dash Kit Vinyl wrap
- Side mirror CF cover
- IPL Rear Bumper
- Illuminated kick plates
- GTR-R35 Clear Map Light Lenses
- KP Technologies Window Roll up Module (Not installed, but will be included - allows you to roll up the window with your keyfob)
- KP Technologies Electronic Beep Module (Not installed, but will be included - this changes the horn sound when locking the door with your keyfob and instead does the beep)
- Z1 2-Piece Akebono Front & Rear rotor (Installed 3 months ago ~4k miles usage)
- EBC Brake Pads
- Replaced Window surround weather strip
- BC coilovers
- GT-R Red Start button
- Eibach Sway bar
- Stainless Brake Line
- OEMassive Headlights
- QS Front Bumper W/ Fog lights
- 10MM Wheel Studs
- 5MM Spacer
- Z1 VQ Performance Header
- Z1 High Energy Ignition Coil
- OEM GTR Spark Plugs
- OEM Emission Canister replaced
- Transmission Pan & Gasket changed less than a year ago
- Replaced Alternator
- Changed Serpent Belt & Pulley
- Ceramic Tints: 5% all around (If you are not used to tints, highly recommend changing the front windshield tints to at least 20-35%)
Map 1: Race Mode
Map 2: Flame/Burble-Pop Mode
Map 3: Economic Mode
Map 4: Security (Shuts off engine)
Disclaimer: Vossen Wheels on the picture not included, car will come with stock wheels, can include picture at your request. If you'll like the Vossen wheels I can include it for an additional $1K - Tires still have 50-60% tread
I have pictures of when the car was stock and how it started to change over the years. I can add more pictures at your request on this link:
I have the lower mesh that goes on the front bumper. Is not installed on the pictures but I have it and will be included, just need to cut the mesh the size for the bumper.
Let me know if you have any questions.
tripled
Aug 23, 2023 10:37 PM
happyday0014
May 19, 2015 04:28 AM
Status Elite
Picture Share G Coupe
Sep 18, 2009 04:46 PM
