FS BC Coilovers & Camber Kit
BC Coilovers Type BR
Price: $700
Location (State/Prov): FL
BC Racing's BR Series is perfect for street driving and occasional road course duty. With easily accessible adjustment ***** for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and patented concave lower locking ring keeps it locked in. The pillowball mount option provides the most available feedback possible from your suspension and to sharpen your steering response. All this while providing a strong, attractive looking coilover system.
The BR series coilovers use a large 44mm diameter piston in a 53mm diameter damper body to maximise oil capacity. As the damper unit operates the oil contained within heats up. The viscosity of oil changes as it's temperature varies which can lead to changes in the damping characteristics of the unit.
BC Racing uses a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil which in turn reduces the peak temperature and significantly improves damper performance.
Key Fetures include:
Mono-tube Shock Design
30 levels of damping force adjustment for compression and rebound
Pillowball Mounts
Separate full length height adjustability
One year warranty
Rebuildable
Pillowball Mounts
One year warranty
Rebuildable
