FS cobb access port
cobb access port
Category: Engine - Power Adders
Price: $250
Location (State/Prov): TX
updated price..
$250 + fees
these are the maps that are installed:
Anti Theft Mode v100
Anti Theft Mode. Car will not be allowed to start.
Anti-Theft Mode v103 - For use with 2008 USDM G37 (AT) vehicles. This map was designed to not allow the vehicle to start.
Installed Stock Mode v103 - For use with 2008 USDM G37 (AT) vehicles. Uses stock values for conditions when you need the vehicle's ECU to act like it is still stock. DOES NOT UNINSTALL AP FROM THE ECU.
Stage 2 91 OCT v100. Intended for a vehicle with stock intakes, hi flow catalyst, and an aftermarket exhaust. For use with 91 Octane fuel of better.
Stage1 91 OCT v100. Intended for stock intakes and stock catalysts. Aftermarket cat back exhaust is approved. 91+ octane fuel.
Stage1 91 v103 - Intended for 2008 Infinity G37 (AT) otherwise stock vehicle with a stock or cat-back exhaust and STOCK INTAKE SYSTEM ONLY. Minimum 91 octane petrol.
Stage2 91 v103 - Intended for 2008 Infiniti G37 Coupe (AT) otherwise stock vehicle with a stock or cat-back exhaust, high flow catalytic converters, and STOCK INTAKE SYSTEM ONLY. Minimum 91 octane petrol. Rev Limit is set +500 RPM above the factory settings.
Stage2+ 91 v103 - Intended for 2008 Infiniti G37 Coupe (AT) otherwise stock vehicle with a cat-back exhaust, headers, plenum spacers, high flow catalysts or race pipes, and aftermarket intakes. Minimum 91 octane petrol. Rev Limit is set +500 RPM above the factory settings.
Stock Style Mode v100 - Stock Style Mode map. Uses stock values for conditions when you need the vehicle's ECU to act like it is still stock. DOES NOT UNINSTALL AP FROM THE ECU.
G37 ACC MT STG2+ REV 1
To be used with a TBE, Hi Flow Cats, Inatke, and Header. 91 OCT or better.
G37 ACC MT STG2+ REV 1T
Valet Mode v103 - Valet Mode for 2008 Infinity G37 (AT) vehicles with STOCK INTAKE SYSTEM ONLY. Rev limiter set to 3200 RPM
