FS Swift lowering springs G37X sedan awd 08-15
Price: $200
Location (State/Prov): OR
$200 pickup in Portland Or or shipping available. 33lbs from 97213. PayPal accepted.
I originally installed them without camber kits. The camber was -1.5 in the front and -2 in the back. Toe can be adjusted back to factory spec, camber has minor adjustments from factory in the rear and none in the front. I added front and rear camber kits a month later and ran -.5 front and -1 rear camber. Without camber kits your tires will be ok if you get the toe adjusted correctly soon after install. You can make the rear camber better with toe bolts for fairly cheap.
