FS Hotchkis Sway Bars - 22441
Old Dec 15, 2013 | 12:18 AM
Rob's-G37s's Avatar
Rob's-G37s
Price: $310
Location (State/Prov): FL
Selling a set of Front and Rear HOTCHKIS Sway Bars for the 370Z and G37. Used but in great condition. These Sways make a noticeable difference to the car's handing and are highly recommended in the various reviews found online.
$310 Shipped to Continental USA. Discount possible for local sale in Central FL. Photos are of the actual items...
Attached Thumbnails Hotchkis Sway Bars - 22441-img_0605.jpg   Hotchkis Sway Bars - 22441-img_0609.jpg
Old Dec 17, 2013 | 01:02 PM
SwissCheeseHead's Avatar
SwissCheeseHead
Coupe? Sedan?
Old Dec 17, 2013 | 01:29 PM
adam3k88's Avatar
adam3k88
Will these fit 2010 G37x sedan?
Old Dec 17, 2013 | 01:55 PM
Rob's-G37s's Avatar
Rob's-G37s
I hope this helps...
From the Hotchkis web site for Part Number 22441:
Application Guide:
09-10 Nissan 370Z
07-10 Infiniti G35/G37 Sedan 4dr
08-10 Infiniti G37 Coupe
08-10 Infiniti G37 S Coupe
Description:
Enhance the cornering performance of your 370Z or G37 with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets
Item # 22441 RWD Models Only! Does not fit All Wheel Drive models.
AWD Models Use Kit # 22443
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.125 (28mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your 370Z, G37 or G35
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
Front Sway Bar 35mm (Ø1.375") Hollow
Spring Rate: 1970 lbs/in
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G35S
+205% Stiffer than stock 370Z
Rear Sway Bar 28.5mm (Ø1.125") Hollow 3 Way Adjustable
Spring Rate: 930, 1160, 1490 lbs/in
+140, 205, 290% Stiffer than Stock G37
+15, 40, 85% Stiffer than stock G37S
+70, 110, 170% Stiffer than stock G35S
+70, 110, 170% Stiffer than stock 370Z
Old Dec 21, 2013 | 09:10 AM
Rob's-G37s's Avatar
Rob's-G37s
Sways are still available....
Old Jan 22, 2014 | 10:43 AM
espimax's Avatar
espimax
So still available?
Old Jan 22, 2014 | 11:58 AM
Rob's-G37s's Avatar
Rob's-G37s
Thanks for your interest, but they are SOLD!!!
djdiskino
Sep 29, 2015 07:18 PM
GFTW
Sep 19, 2015 03:52 PM
