FS Uprev Cipher cable
Uprev Cipher cable
Category: Engine - Power Adders
Price: $170
Location (State/Prov): WA
$170 shipped
Cipher - Data & Diagnostics
Cipher communicates using Nissan’s proprietary communication protocol which enables you to view data with more speed than generic OBDII scan tools giving the user better insight into how the vehicle is running. Sample rates of 20 times per second can be achieved on more than 15 sensors at a time.
Simple ECU and BCM Control
Cipher also provides the user with basic dealership work support routines for the ECU and BCM including:
Target Idle RPM
+/- 2 degree static timing adjustment
Cylinder power testing
Clear Learned Fuel settings
Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
Fuel Pressure purge
Ethanol Adjustments (if vehicle is equipped)
Coolant Test
Supported Parameters:
Below is a short list of available data parameters...
Engine Speed - RPM
Throttle Position Sensor
Vehicle Speed
MAF Sensor
Calculated Load Value
Oxygen Sensor
Ignition Timing
Accelerator Position
Wide Band A/F Voltage (equipped vehicles)
Coolant Temperature
parkern
Oct 5, 2015 12:12 PM
