DPE G - GTM TT, Stoptech BBK & More!
Well been busy since my last started thread. Here is the build as she sits, wish I had more quality pictures, but here is what I have. All of the work on this car was completed by myself in my garage with no lift and only hand tools, so I have an extra since of pride in this build. Special thanks for Jon @ Z1 for the final tune, which put her at 485hp/413tq and a nice smooth power band @ 10psi. After ZNationals this past year the mod bug bit in the performance department, and here she is.
Exterior:
Aero Front Bumper
Aero Side Skirts
AutoKitsX v2 C/F Rear Diffuser
JDM Amber Turn Signal Tail Lights
Gloss Black Headlights w/Satin Shrouds
Gloss Black Grill w/Satin Emblem
TSX-R Projector Lense Swap
Wheels, Suspension & Brakes
DPE CS5v2 20x11 +38 Rear Wheels
DPE CS5v2 20x9.5 +25 Front Wheels
285/30/20 Toyo T1R Rear Tires
245/35/20 Toyo T1R Front Tires
KWv3 Coilover Suspension
SPC Front Camber Arms
SPC Rear Camber Arms
Stillen Front Sway Bar
Stillen Rear Sway Bar
GT Spec Strut Tower Bar
StopTech 6 Piston 380mm Front Big Brake Kit
StopTech 4 Piston 345mm Rear Big Brake Kit
StopTech 2 Piece Drilled Rotors Front & Rear
StopTech SS Brake Lines
Project Kics NeoChrome Lug Nuts
Engine & Electronics
GTM Stage 1 Turn Key Twin Turbo Kit
Z1 Setrab 34 Row Oil Cooler Kit
Fast Intentions Catback Exhaust
Z1 Test Pipes
Southbend Stage 3.5 Clutch
Southbend Lightweight Flywheel
ZSpeed HD Clutch Slave Cylinder
ZSpeed SS Clutch Lines
Greddy Profec Electronic Boost Controller
Tuned By Z1 Motorsports - THANKS AGAIN JON!
Pictures Courtesy of Evan Butts (EBPhoto)
<iframe width="560" height="315" src="http://www.youtube.com/embed/7swuQmL4RiQ" frameborder="0" allowfullscreen></iframe>
See you guys at ZDayZ!
I will eventually add some pictures I took as this all came together and add them but for now just the beauty shots!
Exterior:
Aero Front Bumper
Aero Side Skirts
Z1 Test Pipes
