Vossen matte silver CV2 mini shoot
Old Nov 26, 2010 | 03:21 PM
  #31
VONYC's Avatar
VONYC
Originally Posted by Kverd88
Why is it that Vossen only runs a 9 wheel in the front? I never understood what they don't use 9.5. Wouldn't they be able to get more lip or more concave depending what wheel model and design it is?
Maybe a one piece 9.5 wheel doesn't fit all the cars a 9 wheel fits. Vossen would be loosing customers if that's the reason.
You want a big lip with nice concave get 3 piece wheels.
Old Nov 27, 2010 | 12:34 AM
  #32
speedracer g37's Avatar
speedracer g37
do they do a 35 and 37 offset used on gt30's to get a wider lip or is that just not possible with a one piece vossen wheel?
Old Nov 27, 2010 | 12:58 AM
  #33
TomieG's Avatar
TomieG
Originally Posted by Wicked_limitz
Looks very clean
+1 Lookin clean VONYC
Originally Posted by BlkHR37S
+5/20 offsets after front 15mm spacers and 5mm rear
Whoa u went +5 in the front? Thats with the s-tech drop & stretched tires? Any rubbing with that setup?
Im running +13 all around and the front i can deff go more aggressive but i do not want to rub & want full turning radius. On the rear its poking but i need to stretch the tire more
Yes fool but I ain't no *****, so more aggressive it is
Originally Posted by VONYC
Lol.. IMO 245/275 +20/25 FTW. After experiencing countless setups from 305-255 tires and from +35 offset to +5 in the front ... This is my fav set up of all.
It's simple, clean, aggressive and comfortable.
Thanks for all the comments guys I'm glad u like it.
Glad to see that people are moving up from +30 offsets
~ 20 offset is perfect for the G running normal sized tires
Not shaky shaky tht bad Jay but def prefer not running spacers cause you can't use Hub Rings w spacers wich was my biggest concern and it's temporary so no bigge , def a great look though , I hope Vossen Releases 15/20 offsets for the Stretch tire guys.... O Yeah SUCK THIS 8------->
Im running Ichiba/Project Kics hubcentric spacers along with hubrings on my volks. No vibrations here
Old Nov 27, 2010 | 01:25 AM
  #34
VossenG37S's Avatar
VossenG37S
Well w my 5mm akata spacers , they are just a flat spacer !!!
Old Nov 27, 2010 | 01:34 AM
  #35
VONYC's Avatar
VONYC
Answered your own questing. Simple Vossen one piece can't go more concave not because of offset but because wheel design and manufacture. If it was more concave it wouldn't be safe for the wheel.
Old Nov 27, 2010 | 01:38 AM
  #36
VONYC's Avatar
VONYC
No rubbing with +5 and 235/30/20 in the front. I had a +20 offset with a 15mm spacer.
The spacer issue to let you all know. If you want to run a spacer and get no vibration you must buy a hubcentric spacer. Project kits sells perfect ones with exteded studs bolted on already.
The spacer that Diego had was a flat plate that went on the stock studs. If you use that the it takes spacer away on the stock hub for the hubring to sit on, thus causing vibration......
Old Nov 27, 2010 | 01:41 AM
  #37
VossenG37S's Avatar
VossenG37S
Yes exactly ^^^^ well said X ....
Old Nov 27, 2010 | 11:57 AM
  #38
majin ssj eric's Avatar
majin ssj eric
Silver is definitely the right choice! I hate black rims....
Old Nov 27, 2010 | 12:43 PM
  #39
myk1013's Avatar
myk1013
Very nice!
I'd like to see this set up on a AG or PG.
Old Nov 28, 2010 | 05:06 AM
  #40
JoshLee89's Avatar
JoshLee89
So Von. Just to confirm.
with my 20/25 offset on S-tech,
I wont rub with 235/35/20 and 275/30/20?
Even with ppl on the rear seats?
I currently have 235/35/20 and 265/30/20
Old Nov 28, 2010 | 11:32 AM
  #41
VONYC's Avatar
VONYC
No rubbing with 275/30/20 rear and +25 ... only thing I have my bracket shaved so I can't tell you it won't rub if the bracket isn't shaved. There is still enough room for a 5mm spacer so it's possible it won't rub if you have the bracket.
Old Nov 28, 2010 | 11:34 AM
  #42
VossenG37S's Avatar
VossenG37S
Josh go 245/35/20 285/30/20 !!! Just set rear camber between -2.0-2.5
Old Nov 29, 2010 | 10:00 PM
  #43
JoshLee89's Avatar
JoshLee89
I think after burn this generals out, I wanna try 245/35/20, and 275/30/20. I dont want to have any - camber. ANd yeah I have brackets shaved.
Old Nov 29, 2010 | 10:10 PM
  #44
VossenG37S's Avatar
VossenG37S
That's the way to go...
Old Nov 30, 2010 | 09:21 AM
  #45
MSCA's Avatar
MSCA
Need wider tires on those wheels. The tires you chose are too small. Just look at the gap on the rim of the wheel.
