Teaser Pics: Braille Battery... My G37 just lost 15lbs :)
Old Jul 13, 2008 | 04:06 PM
B L U E S L A T E's Avatar
B L U E S L A T E
Are they as good or better than the Optima Yellows??
Pretty interesting size if you ask me....
Old Jul 13, 2008 | 04:26 PM
Kidcane's Avatar
Kidcane
Florida G Club
Very cool. I was just thinking about this the other day. Any one know how much these are going to run?
Old Jul 13, 2008 | 05:12 PM
Blackjack's Avatar
Blackjack
Looking nice! 15 lbs... Wow!
Old Nov 7, 2008 | 04:31 PM
Dz Nuts's Avatar
Dz Nuts
I'm wonerding the same thing. Anyone know how these compare to the Optima Yellow tops?
Old Nov 7, 2008 | 04:35 PM
nogoodname's Avatar
nogoodname
wow, tiny battery......but very cool
Old Nov 8, 2008 | 02:11 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
everything i have read says better .... i also read optimas arent as cracked up as they used to be... i mean they do sell them at Sams....lol
Old Nov 8, 2008 | 10:27 AM
J.Oh's Avatar
J.Oh
everything i have read says better .... i also read optimas arent as cracked up as they used to be... i mean they do sale them at Sams....lol
this thread and your DPE thread you put sale instead of sell and its starting to bug me. i was going to point it out earlier but..... yea FIX IT
Old Nov 8, 2008 | 11:48 AM
MaxToTheG37
fruitcake^
Old Nov 8, 2008 | 11:03 PM
ChOy BoY's Avatar
ChOy BoY
i'm gonna hafta pick one up!
Old Nov 9, 2008 | 12:36 AM
NeverBoneStock's Avatar
NeverBoneStock
There is lots of info on these batteries at MY 350Z.com and they get bad reviews .. You can pick one up for cheap in private classifieds .
Old Nov 9, 2008 | 12:44 AM
Dz Nuts's Avatar
Dz Nuts
Thanks for the feedback.
I'm going to pick one of these up. Just wanted to know if you opted for the additional aluminum mount kit or if the mount you received came with the battery?
Thanks
DN
Old Nov 9, 2008 | 01:19 AM
MaxToTheG37
wont find one from me... This has more power than the stock battery hands down...and its lighter...
Old Nov 9, 2008 | 03:48 AM
ucla bruin's Avatar
ucla bruin
What's the difference between this and the stock battery other than the look and weight?
__________________
Old Nov 9, 2008 | 04:46 AM
  #29
Dz Nuts's Avatar
Dz Nuts
Appreciate the heads up.
I did a few google searches (not a MY 350z.com member) just now and the only threads I pulled up on the MY 350z.com site were in regards to Braille batteries that were for sale. The posts I found were all in reference to 11lbs or 15lbs Braille batteries, which do have less power. Apparently they did a group buy at some point.
I'm looking at getting the 21lbs Braille battery and couldn't find anything negative about it.
I will continue to do my due diligence based on your feedback and if you have any other information to add it would be welcomed.
Thanks.
DN
Old Nov 9, 2008 | 04:52 AM
  #30
Dz Nuts's Avatar
Dz Nuts
Pulled this form the Braille site...
I don't have the stock specs with me now.
B3121C - Technical Specifications
Model Information Model Number:Braille SKU #B3121C
Model Name:21 lb Extreme Use Battery
Physical Specifications BCI Group: Usable for all Group Sizes
Length:6.6"
Width:5.2"
Height (without posts):6.8"
Minimum Weight:21 lbs
Performance Voltage: 12 Volts
Full Charge Voltage:13.8 Volts
Short Circuit Current (Max Cranking Amps):3000 est.
Pulse Cranking Amps (PCA) 5 sec @ 80F: 1380
Pulse Cranking Amps (PCA) 10 sec @ 80F:1207
Pulse Cranking Amps 20 sec @ 80F:1066
Cranking Amps 30 sec @ 80F:892
Cranking Amps 30 sec @ 32F:742
Cold Cranking Amps 30 sec @ 0F: 550
Reserve Capacity: 1hr 15mins
Capacity (C/20 rate): 31 amp hr
Internal Resistance:4.0 milliohms (.004 ohms)
Life Cycle @ 10% DOD: 3500 cycles est.
si_driver
Aug 23, 2017 01:35 PM
Badgerman
Aug 19, 2015 02:26 PM
Thirty_Seven
12
Aug 16, 2015 01:48 PM
ddayeg37s
Aug 9, 2015 07:10 PM
