Help identify coolant leak
Old Dec 14, 2025 | 12:41 PM
erickv's Avatar
erickv
Yesterday I noticed a small puddle of coolant and when I got under the car I found the leak but can’t identify if it’s coming from the hose or not. My assumption is yes but if anyone could help Identify the hose or if it’s something else. It sits near the passenger side catalytic converter
Yesterday I noticed a small puddle of coolant and when I got under the car I found the leak but can’t identify if it’s coming from the hose or not. My assumption is yes but if anyone could help Identify the hose or if it’s something else. It sits near the passenger side catalytic converter. Thank you
Old Dec 14, 2025 | 06:40 PM
ILM-NC G37S's Avatar
ILM-NC G37S
More than likely the heater hose connector is about to give up the ghost. Get it checked/ replaced NOW before it completely breaks and leaves you stranded.
Search the forum- there are tons of threads describing the issue and offering potential fixes.
Old Dec 15, 2025 | 03:04 PM
erickv's Avatar
erickv
thank you I appreciate it bro. I did further review and it seems to have been replaced already and probably already failing but I will be getting the silicone hose to replace it. If it doesn’t fix the leak do you have any other idea what it could be?
Old Dec 15, 2025 | 03:51 PM
ILM-NC G37S
If the heater hose connector is failing the joints will be wet to the touch. Easy to check/ somewhat easy to replace just tight working quarters. If the connector needs to be replaced be sure it is a metal one. Dorman p/n: 56430 or equiv. ¾" straight, metal hose fitting will suffice.
THIS IS ONE THING YOU DO NOT WANT TO PROCRASTINATE ON. If it is the connector, it will break and likely at the worst time and place imaginable.
In the event the hose connector is not the issue then you will have to visually check all of the hoses and clamps for signs of leakage. The usual suspects are the throttle body hoses, the rear crossover pipe/ hoses, and, on some cars, the driver-side hoses/ connections.
This is just one of those items that require a hands-on approach.
jasonewarren
Dec 11, 2025 10:47 AM
Viclovin371
Sep 3, 2021 12:29 AM
Oscar100K_G
May 18, 2015 11:20 PM
FrankieMigs
Site Feedback & Suggestions
May 7, 2015 09:25 PM
