Help - car won't start
Old Jan 19, 2021 | 05:48 PM
Shane Sheffield's Avatar
Shane Sheffield
Newbie just gifted an 09 g37 sedan. She suddenly wont start and bith key lights are on as well as the cooling fan comes on immediately. Battery tested good and full charge. Also obd scanner will no longer sync although it did fine before. Any ideas folks?
Old Jan 19, 2021 | 10:51 PM
SkysG37's Avatar
SkysG37
Leave car batt unhooked while you procure and install fresh key fob batteries.
be 100% sure car battery is fully charged and load tested before hooking it back up and try again.
Also check if the scanner you are using need's a battery or is powered through the obd plug.
IF it still won't start, follow whatever procedure is laid out in the factory service manual
Old Jan 19, 2021 | 11:14 PM
Shane Sheffield
thanks for the reply. Baterry tested and 100%. Obd is powered through the port. Brand new batteries in the fobs as well. Checked those volts too. Ill look into the fsm tomorrow and look into the bcm voltages too. I tried to upload a short vid but that did not work. Will look into linking off google files.
Old Feb 28, 2022 | 08:10 AM
sergaivid's Avatar
sergaivid
what year is your car? Coupe, sedan, 'vert? Is it auto trans or manual gearbox? Do you live in a northern or Southern climate? vidmate app downloadinsta save
Jbeck
Jun 2, 2022 08:46 AM
RhiNoKiLL
Jun 21, 2011 12:53 AM
Redvoodoo
Jun 8, 2011 12:37 PM
hopgo
Dec 15, 2007 06:44 PM
