2008 Infiniti G37 Coupe
Old Aug 8, 2019 | 09:16 PM
Delry Wilson's Avatar
Delry Wilson
Help Im trying to replace my expansion valve and cant get this damn blower housing out of the way. I have removed all visible screws and it is still stuck. Is there a screw Im missing? Do I just pull on it and it will come lose? Of course there are no videos online for this. Please help.
Old Aug 8, 2019 | 09:35 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Not sure how much this will help... item #7 says to slide the blower to the right, remove a pin, then pull down. Maybe this is what is holding you up?
Old Aug 8, 2019 | 10:09 PM
Delry Wilson
Thanks for the reply
Old Aug 8, 2019 | 10:12 PM
Delry Wilson
It looks like its just removing the motor. I need to remove the entire blower motor housing. Im trying to get to the expansion valve that is behind it.
Old Aug 8, 2019 | 10:35 PM
ILM-NC G37S
My bad, I misunderstood. If you haven't already, I would recommend you download the Factory Manual for your car and check over them.
Here is the link: 2008 G37 Coupe FSM
In this case you will want Sections HA (Heater/ Air Conditioning) and maybe VTL (Ventilation). It would be wise to download the whole manual while you are at it.
Wish I could be of more help. Hopefully someone else here can offer some tips/advice.
Good luck!
Old Aug 9, 2019 | 12:00 AM
Delry Wilson
Thanks again
g-power
Mar 17, 2013 11:18 AM
GT-R
Mar 25, 2007 12:22 PM
