On the market for G37
Old Feb 12, 2019 | 09:43 PM
ezbme's Avatar
ezbme
Originally Posted by camb003
I get you and will try re-beding first, thanks. I ended up purchasing this car and wow what a ride. The previous owner had bought new tires in 2015 but the front tires probably need replacement so it may be a good time to check pads.
I also posted about wind noise above 80mph. Is this common in this model?
Are the service manuals for 2010 coupe S available here?
Also does this vehicle has a time chain? If so do you guys still adjust the tensiometer and change water pump when schedule comes?
They do have timing chains. I haven't had the Water Pump or Tensioners replaced. Mine only has 187500, I think that would be more for 350k miles. I have had all the fluids replaced except the power steering fluid, which I probably will soon.
e90mdrei
Buying & Leasing
Sep 6, 2008 07:28 AM
WRAH
General Tech Questions
36
May 8, 2008 05:54 PM
changchi
Jul 3, 2007 01:17 PM
