Some performance on a limited budget
Old Apr 15, 2017 | 04:32 PM
KenKannon's Avatar
KenKannon
Hey guys..so far I have my x coupe for close to 2 months and love it..have been looking on the forums a lot and have come up with a plan to do some modifications to help some better handling..and wanted to see if you think there is anything else I need
1. Rear sway upgrade...looking at going for a used 370z/s coupe rear sway with upgraded end-links and bushings.
2. Mild lowering springs and 20mm spacers (and alignment)..was looking at the Eibach pro-kit but don't want to mess with the camber too much or have the budget to drop $700 on a camber kit...any recommendations on some options that would give me a mild drop and not take the camber out of spec? Tein maybe?
Old Apr 15, 2017 | 05:24 PM
Swift springs would be the best bet, but a rear camber kit may still be needed, alignment can vary quite a bit between vehicles and the techs/shops performing the aligning. Eibachs drop a bit deeper and Tanabes are prone to dropping the back deeper than the front.
