Eibach Pro Kit & Camber Question
Old Oct 23, 2013 | 06:46 PM
GXXXVII's Avatar
GXXXVII
Hello People - Im the owner of a Slate Blue G37S 6MT - I love this car!
Now for the question: I just bought an Eibach Pro Kit and Eibach Camber Kit (front & rear). Can I install both kits at the same time and then go get an alignment?? Some folks say to install the springs first and get an alignment. Take the alignment numbers and use them when you install your camber kit so you can adjust accordingly...that really confuses me. Would you not have to get it realigned again? I only want to pay for an alignment one time here..
Please advise...
thanks!
Old Oct 23, 2013 | 07:06 PM
Yep, just install the lowering springs at the same time as the F&R camber arms & rear toe kit then take it for the alignment. Be sure to wait a week or so for the springs to settle in before taking it to get aligned. Also be very careful driving it prior to the alignment, I'd keep the driving to a minimum, springs will settle just fine without driving it much.
Also it's best if you find a shop that aligns lowered vehicles on a more regular basis, shops that just deal w/ stock rides tend to have a tough time figuring out aftermarket camber setups
Old Oct 23, 2013 | 08:59 PM
GXXXVII's Avatar
GXXXVII
Thank You - I appreciate your quick response!
Glenn
Old Dec 31, 2013 | 07:27 PM
SlateBlueG's Avatar
SlateBlueG
Glenn,
Welcome to the forum and hope your install and alignment went well. BTW, my name is also Glenn. Wait, it gets funnier - I also have a Blue Slate G!
Old Jan 1, 2014 | 04:06 PM
algeee37s's Avatar
algeee37s
Please advise...
thanks!
Hi Glenn,
I am looking at either the Eibach or SPC Camber Kit, how is the Eibach Kit and do you recommend it?
Old Jan 1, 2014 | 04:43 PM
Originally Posted by algeee37s
Hi Glenn,
Eibach & SPC are the same kit just under different brand names, you should find the SPCs to be a bit cheaper. The F&R kits (including rear toe kit) goes for about $500 complete.
Welcome to the site algeee37
Old Jan 1, 2014 | 05:15 PM
algeee37s's Avatar
algeee37s
thank you for the reply, well that settles it, i will get the SPC. Thanks again for the help
Old Jan 13, 2014 | 10:52 PM
Lv8's Avatar
Lv8
I also have a slate blue g37xs also new to this forum
How low is the eibach lowering springs and is the ride quality decent. Looking to put 20 s on too .
Any help would be appreciated
Old Jan 13, 2014 | 11:19 PM
Welcome to the site Lv8
Going to lower profile 20" tires combined w/ the firmer lowering springs will make for a rather dramatic change in ride quality. I like the firm ride and more connection to the road w/ 20s but you will sacrifice quite a bit of comfort.
Also when going w/ new wheels & tires be very careful w/ the new tire diameters. AWDs are particularly sensitive to a variance ffrom stock diameters. You can go w/ bigger wheels & wider tires but best to keep the diameters of your new set withion 1% of staock diameter. For specific tire & suspension questions please browse & post in this folder
Brakes, Suspension, Wheels & Tires - MyG37
G37xhibeet
Nov 15, 2016 09:29 AM
Simran Mann
Sep 13, 2015 01:51 AM
equifire
Aug 31, 2015 03:42 PM
Ipp391
Aug 28, 2015 09:27 AM
kyro840
Aug 9, 2015 01:38 PM
