need some winter tire advise
Old Oct 29, 2011 | 03:13 PM
Greg S's Avatar
Greg S
I have a 2010 G37xS sedan - struggled through a rather slippery Canadian winter last year so now I'm looking for winter tires and wheels. Some tire retailers are telling me I must stick with the 225/50/R18's but other say I can downsize to 225/55/R17's. I'm hearing the Blizzak LM-60 is the best tire (also most expensive) but I'm also hearing that the tread wears quickly. Any advise?
Old Oct 29, 2011 | 03:24 PM
ohjames24's Avatar
ohjames24
Firstly.. It's 'advice'
EG. someone gives you advice when they advise you =D
Anyways, If you are looking for a dedicated winter set on 17's then you should definitely go for the Blizzak WS-70 (225/55/17) all around. On the 18's ur best choice would be the pilot x-ice Xi2.
The LM-60 has the same tread pattern as the WS-70 (mostly) but the compound which comes in contact with snow and ice is very different since the LM is a performance winter tire and not a snow/ice tire. The WS is unavailable in the 18 in size.
SUM - the WS-70 = best tire for snow/ice (17 in only)
- x-ice Xi2 = best tire for snow/ice (18 in category)
Old Oct 29, 2011 | 03:31 PM
JSolo's Avatar
JSolo
Just say no!!!!!
In general, you want to use the smallest width tire, but one that will retain a similar diameter to your stock setup. Taller sidewalls will also help cushion the car when you hit those bumps/potholes you can't see under the snow/slush. From what i've read, 17" should work if you don't have the oversized brakes.
j50ny
Jul 21, 2017 10:46 AM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
footballmania32
Sep 4, 2015 02:17 PM
ZachThomas
Sep 3, 2015 01:40 PM
