vossen offset??
I've seen also Eibachs w 20/25 and 235/35 265/30 W out rubbing. 275s I have yet to see w Eibachs drop . Just one guy on S techs that pulled it off at +25 w 275s and that was low but he modIfied his rear brackets and never rubs , I think u will b ok just test it out. Worst case u trim your rear bracket and u will b good to go.
I am on 275's at +23 and my car is very low on BC's and around -1.5 neg camber but I removed the liner, shaved the **** out of my bumper bracket and even pulled my fender about 2-3 more mm.
Idk if i could handle doing that , but fender liner and bracket should be ok to remove . Damn Kid any pics of your Rears ?? i wanna see.
I dont have any good pics where you can really see it. I will try to snap one later on my phone and post it.
Edit: Found a couple. Sorry for the thread jack!
This was before I lowered it a little more and pulled the fender.
This is after I dropped it further but still no pulled fender.
OK well this is just about the worst pic ever but you may be able to see where I pulled the fender. It is literally only a few mm so barely noticable but just needed that little more to keep it from rubbing. If you look there is a slight crease near the edge where it flares out a tad. I used a tool made for rolling fenders and heat gun.
