How do YOU downshift?
Old Jan 14, 2011 | 07:08 AM
  #31
MSCA's Avatar
MSCA
Originally Posted by Ken
Sorry but you got things completely backwards with your misunderstanding. First, double clutching an upshift is funny.
It's funny? I don't see how you'd think it was funny. Before the days of synchromesh gearboxes, truck drivers would have to double clutch every upshift they made. Of course we don't have to do that today, but if you happen to drive a car with weak or worn synchros, you can easily get by just fine by double clutching on the upshift. That's a fact.
The only time I've heard of that was from Vin Diesel in The Fast and The Furious . "Granny Shiftin, not double clutching like ya should. Now me and the mad scientist gotta rip apart the block and replace the piston rings that you fried." Classic. Hopefully no one would take anything but entertainment value from that movie. I have to hand it to semi-truck drivers though for their need to double clutch upshifts since their rpms drop quickly between shifts due to their cargo loads. Unless you upshift like a grandma whose never driven stick before, double clutching an upshift does nothing since engine and transmission speeds are already up due to acceleration. Are you Vin Diesel?
Yeah, I'm Vin Diesel. Got a problem with that? What's really funny is that you think double clutching is only needed due to 'cargo loads'. Now that's funny. Truck drivers used to double clutch because they had to, regardless of the load they were pulling. That's a fact.
Old Jan 14, 2011 | 07:15 AM
  #32
MSCA's Avatar
MSCA
Can double-clutching eliminate gear clash due to sychros wearing out before you are ready to get rid of your car?
Gears NEVER clash in a modern manual gearbox. That's because all the gears are always in constant mesh. It's impossible for the gears to grind unless you have one or more broken gears. And if that's the case, you're screwed anyway.
Do you even realize what that grinding sound you hear when you do something stupid with your transmission? Hint: it's not the gears in the transmission.
Old Jan 14, 2011 | 11:41 AM
  #33
Ken's Avatar
Ken
Not true. I've driven a 1970 Chevy truck 4speed MT and could do it without double clutching upshifts--down shifts on the other hand you would have to double clutch if you wanted to change gears quickly. You got it backwards.
Old Jan 14, 2011 | 11:43 AM
  #34
Ken's Avatar
Ken
Gears clash if you have worn synchros.
Old Jan 14, 2011 | 12:35 PM
  #35
1NEETO's Avatar
1NEETO
Wrong. Synchronized transmissions are NOT constant mesh. Only unsynchronized transmissions like those on big rigs and motorcycles (and some racing "dog boxes") are. That's the job of the synchros on a synchronized manual transmission, to synchronize the gears so they don't clash. A constant mesh transmission doesn't need a clutch to up or downshift, the only time I ever double-clutched a big rig (I drive those things on a daily basis) was when I took the CDL DMV road test. Since then I never use the clutch until I come to a complete stop.
So yes, when you drive your 6MT and you grind the gears, that IS your gears begging for mercy.
Old Jan 14, 2011 | 01:01 PM
  #36
MSCA's Avatar
MSCA
You need to do some research. You're 100% wrong. Our gearboxes are constant mesh, as are just about every MODERN gearbox on every manual trans car. The job of the synchro is to match up SHAFT speeds, not gears. Yes, the gears rotate on the shafts, but they are already in constant mesh. Don't take my word for it, look it up yourself if you don't believe me.
I've rebuilt countless T5 transmissions (used extensively on 5.0L Mustangs, as well as other vehicles) and trust me when I say the gears are in constant mesh. If you need me to post pictures, I will.
Old Jan 14, 2011 | 01:04 PM
  #37
MSCA's Avatar
MSCA
First of all, I was talking about the old, big trucks, not a 1970 Chevy. LOL. Back in the days of crash box transmission (you might have to look that up if you're not familiar with the term), the only way to shift WITHOUT making some nasty sounds was to double clutch. Synchronizers have not been around as long as manual transmissions.
Old Jan 14, 2011 | 01:06 PM
  #38
MSCA's Avatar
MSCA
It's not the gears clashing. They can't clash because they are always in constant mesh. The grinding noise you're hearing is the dog clutch, which are part of the synchros.
Old Jan 14, 2011 | 01:08 PM
  #39
Coprolite's Avatar
Coprolite
You need to do some research. You're 100% wrong. Our gearboxes are constant mesh, as are just about every MODERN gearbox on every manual trans car. The job of the synchro is to match up SHAFT speeds, not gears. Yes, the gears are attached to the shafts, but they are alread in constant mesh. Don't take my word for it, look it up yourself if you don't believe me.
I'm interested in learning about this. If they are always in mesh, but they are rotating at different speeds, wouldn't they have to be out of mesh somewhere along the way. What is the definition of mesh? To me it means aligned with each other, like being in phase. Does anyone have a good link for this?
Back on topic: I think the original topic was concerning the interesting behavior of an Automatic transmission and engine rpms? Was it AT or MT Mr. OP?
Darn it this is the wrong thread! Ignore the on topic foobar.
Last edited by Coprolite; Jan 14, 2011 at 01:15 PM. Reason: realized which thread I was posting to...
Old Jan 14, 2011 | 01:13 PM
  #40
MSCA's Avatar
MSCA
This might help you visualize it. Notice that all the gears are constantly in mesh.
YouTube - How Manual Transmission Works
Old Jan 14, 2011 | 01:15 PM
  #41
Kidcane's Avatar
Kidcane
Florida G Club
You guys are going to get another thread locked.
Old Jan 14, 2011 | 01:16 PM
  #42
Coprolite's Avatar
Coprolite
That will help. Thanks
Old Jan 14, 2011 | 01:17 PM
  #43
MSCA's Avatar
MSCA
Why? It's a good discussion and it has turned into any name calling or other foolishness.
If anything, this debate will help people learn how a manual trans actually works.
Old Jan 14, 2011 | 01:21 PM
  #44
MSCA's Avatar
MSCA
Here's a nice picture of a modern constant-mesh manual transmission. If you can visualize it, all the gear sets are meshed and never separate. You can clearly see the groove where the shift fork sit on the synchronizer collar. This is what moves back and forth when you moved the shift lever and the dog clutches help spin up to match shaft speeds.
Old Jan 14, 2011 | 01:29 PM
  #45
MSCA's Avatar
MSCA
Exactly. Someone that's grand touring would turn off all aids and try to enjoy the car on its purest form. Someone at the track is trying to beat his/her previous laptime, so any aids that will help achieve that will be used. Nissan did the right move IMO.
Guys typically turn off electronic nannies at the track because they usually don't hep return the best possible lap times or track speeds. As an example, who wants to race (road course or drag strip) with traction control on? Not me...it will just slow me down as it cuts power if a wheel slips. That's what I meant when I said that someone who buys a G37 because it's a grand touring car will generally appreciate driver aids. And people who are racing (or like to drive like they're racing) will generally like to turn off the driver aids and make the car perform to the best of their own ability. Just my opinion....
