Air Intakes/Headers/HF Catalytic Converters/Cath Back Exhaust
Yes a tune as in flashing the ECU, but you need to have it done by a pro tuner that can make it specific to your vehicle and mods to get the most out of it, like an UpRev tuner.
Breathing mods will help some, but you don't release their full potential until you tune the car for them.
Here's one I found with 320 WHP https://www.myg37.com/forums/engine-...prev-tune.html
Not the best since there are no before numbers. I know G37Sam put down nearly 300whp with all the bolt ons and tune...
I'm pretty sure I saw tuned cars with 330 whp, let me find them...
Hi
Im decided to buy the Stillen Ultralong air intakes, but still unsure about the other components... in view that at this moment I am only interested in naturally aspiration mods (and no intention to change to SC or TC in a nearly future), which components you recommend?
Headers- Short or Long? Stillen, Fast Intentions etc
Catback exhaust? HKS? Stillen? etc
And what about a Intake Manifold? any experience with it? (Kinetix, Motordyne)
In view that it will take several days I want to install all the things in the same week to take the best advantage of a CPU reprogramming
Thanks again
Sam
Thanks again
Sam
I'd skip the headers unless you want really loud/raspy exhaust. I would just get high flow cats or test pipes instead. It really doesn't matter which brand you go with for the exhaust as long as its full cat back, the power between then will be minimal with all the other mods.
As far as manifolds the verdict is still out I think. So far I've heard there were minimal or even negative gains even after a tune.
If I were buying all over again I'd personally go with Fast Intentions resonated test pipes and the Intimidator exhaust with the Stillen gen 3 intakes. Then get a tune on top of that and you should see some very impressive results.
