Increase MPG mods.... any? how about...
Old Apr 9, 2010 | 01:34 PM
crazjayz's Avatar
crazjayz
Originally Posted by tokyo_gaijin
lighter wheels, eco tires filled with nitrogen, keep tire pressure high. smaller wheels will do the trick too.
as far as driving, i am actually surprised how good fuel economy is on highways, but it sucks in stop and go, so basically when you drive in the city, try to predict signal timings, and avoid stopping. dont rev.
Yeah..... that one. Better yet, don't go past 4.5k just to hear your engine. I'm guilty of doing that waaaay too frequently. Costs me at least 5 bucks a week. hahaha
Old May 20, 2010 | 12:17 AM
itisagoodname's Avatar
itisagoodname
Gas prices will only go up. Burn it while you got it!
I commute just under 100 miles a day and enjoy every gas-burning second of it. Can't wait for the CARB approvals for Stillen and GTM. I wonder what FI does to the gas mileage?
Old May 26, 2010 | 10:41 PM
handleandrew's Avatar
handleandrew
ok, people are searching for ways to increase gas mileage by mods...well let me ask this: will mods DECREASE my gas mileage? and i'm just talking BASIC stuff like intake and exhaust. if i do these mods and (hopefully) get increase hp can i AT LEAST keep my mileage?
also, is there that big of a performance difference between the stillen gen 2 and 3 intake? i know the gen 3 is supposed to be supper good, so is the gen 2 even worth getting?
Old May 26, 2010 | 10:50 PM
Pip's Avatar
Pip
Look, if you get an intake and exhaust are you going to stay out of it? That'd be like sending an 18 year old out in a bus full of naked cheerleaders and telling him to look, but don't touch.
Old May 26, 2010 | 10:54 PM
G37Sam's Avatar
G37Sam
On a second note, if everyone is so concerned about gas mileage, why buy a G37 to start with
Old May 26, 2010 | 11:40 PM
handleandrew
probably. i'm not really a tuner i just like having a car thats somewhat unique. most of my knowledge is in electrical anyway, but if i'm gonna spend a grand on intake and exhaust and get a 5hp or even 20hp gain but loose 3 miles a gallon i may consider not doing it. if i wanted a car taht got 13 mpg city i'd have bought a v10. i use my car every day, but not on the track. just looking for a little guidance from people who know thats all.
Old May 27, 2010 | 12:07 AM
Harley'sG's Avatar
Harley'sG
Exactly! Since you're in it though and are concerned try...P90x...weight loss is your friend.
Old Jun 2, 2010 | 03:31 PM
Chomponthis's Avatar
Chomponthis
The money you would spend is not worth it, just make that heavy foot a feather
Old Jun 23, 2010 | 01:33 PM
jabrother's Avatar
jabrother
No one has mentioned a simple mod-- change to a higher aspect ratio tire to increase your gearing. So if you've got 40 series tires go to a 45 or 50. It will throw off your speedo a bit, it might even screw up the VDC, but it should increase MPG and decrease acceleration. And like everyone said, also decrease your wheel size and buy a super light weight yet strong wheel.
Old Jun 23, 2010 | 01:55 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
While on principal that makes sense, it doesn't make practical sense.
Throwing off your speedometer and screwing with the VDC can have very high dollar associations when you have to fix them (or pay the ticket cause you are going faster than you thought)
And the cost of a super light yet strong wheel is on the high end of aftermarket wheels and the money you will save on gas would take about 15 years to make up the cost of those wheels. Now granted I paid a lot for my wheels, but I didn't try to tell myself it was for gas mileage.
Old Jun 23, 2010 | 02:54 PM
Mike's Avatar
Mike
That also increases rotational inertia and rolling resistance, assuming you use the same tire.
Old Jun 23, 2010 | 04:37 PM
jabrother's Avatar
jabrother
You just have remember your correction factor of 2-3 mph! I don't know if there's a problem with the VDC but there certainly could be. Can anyone chime in with factual info there? Here's a lightweight reasonably priced wheel from the tirerack for the G coupe. It only weighs 18 lbs, not sure how much the stock wheels weight, but they're probably more than that.
Enkei Racing PF01
Enkei Racing PF01
Enkei Racing PF01
Finish: Bright Silver Paint
How to View on Vehicle Click the size you would like to see on your vehicle
* 18"
$320
Front and Rear Fitments
18x8.5
Original Price:
Now 0% Off:
$0 (each)
$320
$320 (each)
$0 (each)
See price in cart
Offset: 45mm Backspacing: 6.61" Bolt Pattern: 5-114
Rec. Tire Size:225/50-18
Weight: 18.0lbs.
Old Jun 23, 2010 | 05:40 PM
Mike's Avatar
Mike
RPF1's are lighter than PF01 =P
Old Jun 23, 2010 | 05:51 PM
  #29
jabrother's Avatar
jabrother
How much do stock G wheels weigh??
Old Jun 23, 2010 | 06:28 PM
  #30
Mike's Avatar
Mike
Per BlackBetty:
Originally Posted by https://www.myg37.com/forums/wheels-and-tires/191169-g37-oem-sport-wheel-and-tires-specifications-for-reference.html
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
