Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Wheel/Tire Suggestions for track. What do you track with and why?
Old Mar 28, 2013 | 03:08 PM
kaoticdemize's Avatar
kaoticdemize
I ran some nitto nt-05's on the track, loved em, still good for dd and somewhat decent life. Came form the pilot super sports, these imo were hands down better for both, a little less life though but they do make up in the cost.
Old Apr 8, 2013 | 05:52 PM
Silver_HR's Avatar
Silver_HR
I think the biggest thing with our cars is that they tend towards understeering.
Right now I am more focused on learning performance driving techniques rather than maximizing the car's potential.
With that in mind, I think the first step is to get a square set up on the car, increasing the possible grip at the front relative to the rear (by equalizing tire widths front to rear).
It seems like the cheapest way to do this would be to buy somebody else's OEM wheels for my car.
For track days I could add their rears on my front and put some stickier tire on all 4 8.5" rims
For daily driving I would use their fronts on my rear and run some rock hard rubber on all four 7.5".
Will probably need spacers though to keep everything kosher.
Last edited by Silver_HR; Apr 8, 2013 at 05:55 PM. Reason: Horrible horrible grammer.
Old Apr 10, 2013 | 11:18 PM
joo030879's Avatar
joo030879
Rather than going through all the trouble. You can get similar results just by changing tire pressure.
If under-steer, deflate front tires
If over-steer, deflate rear tires
Old Apr 10, 2013 | 11:37 PM
joo030879's Avatar
joo030879
IMO tires with UTQG:200 good for street and track use. If you go to track once a year. NT-05, Hankook V12, etc.
However when I started to go more frequently 2-3 times a year. Sometimes I would replace them prematurely. Because not enough tread left to pass car inspection at the track.
Since last year I am going to the track at least once a month, and purchased another set of Wheels and Tires dedicated for the race track.
Normal Street USE
OEM Wheels with NT-05 Rear, V12 on the front
Track Use
Enkei NT03+M
18x9.5 +27 with RS-3 245/40-18
18x10.5 +30 with RS-3 285/35-18
In the long run definitely saves $$$
Also if you are interested in some good price RS-3's Gruppe-S in Sanata Ana is selling some 2yr old RS-3's very good price.
265/35-18 $175
285/35-18 $195
They normally sell for $250-$300
Old Mar 17, 2014 | 12:39 PM
SkylineG's Avatar
SkylineG
19" Michelin PSS for DD and 18" Potenza RE11 for track.
Old Mar 18, 2014 | 11:23 AM
SkylineG's Avatar
SkylineG
Normal Street USE
Track Use
Enkei NT03+M
265/35-18 $175
285/35-18 $195
That's not too wide? No issues?
Old Mar 20, 2014 | 06:31 PM
Silver_HR's Avatar
Silver_HR
Also, where did you get your NT03+Ms in Socal? I'm thinking I'll pick a few up as well.
Old Nov 26, 2014 | 11:44 AM
stockae92's Avatar
stockae92
For my G35S sedan, I tracked and DD with stock size 18" 225f 245r. The car does push (understeer) more than I would like.
I've had a set of Falkin 912, they actually had decent traction when the treads are good, but it degrades quickly as the treads wear down and during very hot track days (106F ambient temp, over heating also cause by bad driver)
Then I tried a set of OEM RE050A. I think they are a step above Falkin. Its more consistent, but the grip level doesn't seems much higher than the Falkin.
I bought a set of PSS and those will be next up
For tire pressure, it depends on a lot of things, especially track surface temp. I ran 2 to 5 psi lower than factory recommended. But I am still learning (trial and error) on this part.
And I think I need sway bars ... LOL
Old Mar 6, 2015 | 04:06 PM
zander85's Avatar
zander85
I definitely recommend a square setup on the G37. On the track, the car does tend to under steer a bit more than it should, and therefore not allow you to steer the car with the throttle much because of the lower cornering speeds due to a lack of front end grip.
Recommended tire temps vary on different tires, on Michelin PSS I try to stay in the 34-37 psi range hot (after coming off track).
misc
29
May 24, 2023 03:57 PM
ArmyBoyd
Sep 22, 2015 08:54 AM
