Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
My First Track Day Verdict: I'm Addicted!
Old Dec 6, 2011 | 07:56 PM
Mike's Avatar
Mike
Stick ftw.
Old Dec 12, 2011 | 03:22 PM
WannabeSport's Avatar
WannabeSport
You hit limp mode? Just warming up the car or what??? I never imagined you could do that on a cool day...
Old Dec 12, 2011 | 03:42 PM
sdaigle240's Avatar
sdaigle240
Wow that's cheap LRP in ct is 340$ for 4 20 min sessions. How much actual seat time was it?
Old Dec 12, 2011 | 05:06 PM
Mike's Avatar
Mike
^^ Most track days here have a minimum of 80 minutes of seat time, with the norm being 100 or 120.
Also, people tend to leave as the day goes on for various reasons, so you can always join other sessions in the afternoon (and that sessions's rules would apply to you).
Old Dec 14, 2011 | 03:20 AM
Silver_HR's Avatar
Silver_HR
I dunno. I was just trying to go faster and faster, getting on the gas earlier, staying in it later on the straights, etc.
Except in a few places the track is really WOT or on the brakes (I guess all tracks are actually, haha). To be honest, I really hit limp mode after only two sessions. The first two sessions were follow the leader and probably did not heat the oil too much. So really, it was at the end of my second all-out session (4th session overall) that I hit limp mode, and then the second lap of my third all out session that I hit it again. I let it cool off and tried to go back out in the same session, got about two and a half laps in and then got hit with limp mode one final time before bringing it in.
I think its probably the track. Streets of Willow Spring is tight and technical, because of the large RPM band that you use and because of the relatively low speeds you tend to heat up the oil without the airflow to take some of it away. I assume at other tracks you get over 100 and for longer periods of time, which would tend to sap away some heat?
Just speculation. I know from my heat transfer class (years ago) that simply doubling fluid speed increases the heat transfer coefficient 4x.
Last edited by Silver_HR; Dec 14, 2011 at 03:22 AM. Reason: Because they didn't teach me grammar in engineering
Old Dec 14, 2011 | 03:43 AM
Presto's Avatar
Presto
Originally Posted by Gamedog
Awesome.
Did Streets of Willow last year with ucla bruin and Mike on here and have missed it ever since.
Since you hit limp mode, be sure to change the oil.
Oil cooler? Would only recommend the one from ae performance, as it was the only one that prevented our VQ from hitting limp mode in a comparison between it and 3 others (can't find the link)
Products_Nissan_Z34OCK
Is the above oil cooler a direct bolt on for the g37 coupes? seeing as it says 370z fitment, will the lines be long enough? and will that cooler fit behind our bumper?
Old Dec 14, 2011 | 03:45 AM
Silver_HR's Avatar
Silver_HR
Exactly. This particular day was pretty crowded but the beginners got to have 5 sessions because their first session was really just follow the leader and not much of a session at all. I think each session was about 20 minutes. For us (beginners) it meant about 7-10 laps on a 1.8 mile track.
Old Dec 14, 2011 | 04:06 AM
Mike's Avatar
Mike
You going to WSIR this weekend?
Sunday is EMPTY. UCLA_Bruin and I will be there.
Because the G doesn't have an oil cooler, vehicular velocity has almost no impact on oil temps.
You may want to try switching to a better oil. Lower friction oil will have a large impact on temps. Also, RPMs are the single biggest factor in oil temps. If you're not WOT, stay in a higher gear
Old Dec 14, 2011 | 10:21 PM
Silver_HR's Avatar
Silver_HR
How do I know whats a better oil? I'm running 5w30 mobil 1 right now. Am I supposed to use that Motul stuff? ****'s expensive. Royal Purple? Redline? Amsoil?
Old Dec 14, 2011 | 10:59 PM
Mike's Avatar
Mike
Mobil 1 is pretty bad.
300V is expensive, but you can probably double your miles between changes too, so the actual cost may end up being a lot cheaper than you think.
yeah... I have a slight problem.
Old Dec 14, 2011 | 11:17 PM
Silver_HR's Avatar
Silver_HR
Yer lookin like ya got a shelf-space issue rit' thar. Fer a 20 I coulda helpya free it up...
ya'know just sayin.
Not that I should be talking. I got 5 cases of Mobil 1 because they came in 6 quart cases and I needed 5 per change. 5 cases would make 6 oil changes. But I got them from costco so I can return them whenever.
Old Dec 14, 2011 | 11:26 PM
Mike's Avatar
Mike
300V won't even sneeze at limp mode oil temps (so you don't need to change oil if you do hit limp).
I can find you a supplier if you're local.
Old Dec 15, 2011 | 01:15 AM
ucla bruin's Avatar
ucla bruin
Try ENEOS. It's not as expensive as 300V but has very good results with our engine. Check out mine and Black Betty's oil analysis on extend use on ENEOS.
Won't be at the track on Sunday, but will be there Saturday instead.
__________________
Old Dec 15, 2011 | 02:14 AM
  #29
Silver_HR's Avatar
Silver_HR
I have a family reunion on Saturday and other **** on Sunday. I'm jealous that you guys get to go.
I live in northern orange county if that's local.
Do you just double the intervals with either one of these oils? Even if you have a track day?
Old Dec 15, 2011 | 02:29 AM
  #30
Mike's Avatar
Mike
I don't know anyone who runs a short OCI on 300V, and a lot of these guys drive pretty hard
