Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Track event tomorrow at Thunderhill Raceway in NorCal....question
Old Apr 20, 2011 | 01:20 PM
MOB's Avatar
MOB
Recommended tire pressures?
Old Apr 20, 2011 | 02:08 PM
JEBperformance's Avatar
JEBperformance
Cold 29psi, no lower than 28psi when tires warm up should read between 32-33psi. Check your tire pressure after each and every session. Constantly check your tire pressure, as the day gets warmer. Reverse as ambient temperature drops. When you are headed back home, make sure to refill your tires. To save on gas.
Old Apr 20, 2011 | 02:31 PM
MOB's Avatar
MOB
Thanks John! BTW---the Hotchkis bars made a HUGE improvement. Thank you for getting them to me in time!
Old Apr 20, 2011 | 02:44 PM
Mike's Avatar
Mike
Start with 30 cold, and check IMMEDIATELY when you come off track. DO not do a cooldown lap your first session.
Adjust tires to 38; they'll likely be over. See how the car feels next session, and bleed front if you're understeering, and the back if you're oversteering. Adjust in 1 psi increments, always hot.
Don't forget to fill up before you go home
Old Apr 20, 2011 | 06:16 PM
MOB's Avatar
MOB
Good stuff, thanks peeps. Fun begins at 8:30 mañana. Sweet
Old Apr 22, 2011 | 02:46 PM
MOB's Avatar
MOB
Ok, now THAT was a friggin blast! Had to manage brake fade on only a few occassions throughout the day, but this saloon represented pretty damn well I must say. And I got a real thrill for 4 hot laps in a 458 Italia. Ummm, can you say F1 car with a body. That thing was a monster!
Old May 25, 2011 | 03:12 PM
kaoticdemize's Avatar
kaoticdemize
MOb forgot to mention this but with the fade, replace your brake fluid with motul racing fluid and upgrade your pads, should take car of it.
fuzzed
Aug 21, 2020 09:35 AM
timc00k
Feb 15, 2017 09:15 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
Jckiksass
Upcoming Events
Sep 25, 2015 11:15 PM
