First time at the Drag Strip
Took the car to the drag strip for the first time. Car is bone stock with 2700 miles and the temperature was 42 degrees. My best time of the night was my first one:
R/T - .477
60' - 2.075
330 - 5.882
1/8 - 8.969
mph - 80.22
1000 - 11.585
1/4 - 13.810
mph - 101.80
Overall i'm happy. I need to work on my launch, but the car was running great and chirping 2nd and 3rd gear.
I weigh over 300lbs, so I think this car should be running low 13.6 or so.
R/T - .477
60' - 2.075
330 - 5.882
1/8 - 8.969
mph - 80.22
1000 - 11.585
1/4 - 13.810
mph - 101.80
Just an update. Went back to the track last night with the wife's WRX. She has a 2011 and swears up and down that its faster then my car. she had me drive it so we could do an honest comparo. The fastest I got it was 14.2 @ 95mph and i had to dump the clutch at over 5k rpms to get that launch. She's a little upset as she thought she would beat me easily. i think she believes i let off (i didn't).
Oh well. I know this isn't G37 related, but just sharing a little tidbit.
Edmunds says the WRX Turbo does 0-60 in 5.3 seconds with a stick. The WRX STI does 0-60 in 4.5 seconds.
Edmunds rates the 2009 G37 sedan at 5.4 seconds, so I suspect what she's feeling is the lower end torque and slightly better 0-60 range. I think your G is taking the WRX in the top end.
So now you can tell her the WRX is (sometimes) faster and she'll be happy.
Does she have the STI?
Car and Driver got a 0-60 in 4.7(dumped clutch at redline
) in a 2009 WRX sedan, 1/4 mile in 13.7 at 99 mph. Edmunds.com tested like 4 different new WRX STi sedans and COULD NOT get it to go 0-60 in less than 5.5 seconds or crack into the 13s in the 1/4 mile, they felt as if it was weirdly low on boost. So WRX is just as fast if not faste than the STi off the line, at higher speeds I would expect the STi to pull ahead...
It maybe that they are lighter and boost comes on rapidly around 3000-3500rpm that makes them feel faster. WRXs only go quick with high clutch dumps, which ultimately will result in some part of the gearbox blowing. I miss my rex a bit, but its nothing special at all compared to the G37 (even though it was an 11sec car).
