Cold Start Delete?
Old Jul 13, 2020 | 02:24 AM
gclasslicense's Avatar
gclasslicense
Thumbs down Cold Start Delete?
Anyone here with test pipes done a cold start delete? Heard its useless when you have no cats and will improve MPG, plus your neighbours won't get so mad.
Old Jul 13, 2020 | 09:31 AM
PNW_IPL's Avatar
PNW_IPL
great idea, I believe subie guys do it. Never heard of it on a vq.
Old Jul 13, 2020 | 10:27 AM
SonicVQ's Avatar
SonicVQ
I assume you are talking about the higher idle at a cold start.
If you are tuned, you could adjust the engine coolant / idle RPM map to lower engine RPM and see if that works.
Old Jul 13, 2020 | 12:41 PM
BULL's Avatar
BULL
Moderador
I mean, WHY?
Cold start on these is active for less than 2 minutes and overall if you pay attention to your AFRs the ecu still tries to achieve 14.7 stoichometry.
SO on gas not much will be saved.
Old Jul 13, 2020 | 04:40 PM
gclasslicense
My friend with a 340i deleted his cold start and I was wondering if its possible on a VQ since it is useless with no cats. Anyone know if deleting cold start is problematic during winter months when its much colder outside?
Old Jul 13, 2020 | 07:00 PM
Selym's Avatar
Selym
Personally, I like clean air. To each his own, I guess. 🤦‍♂️
Old Jul 14, 2020 | 07:49 AM
Birdie's Avatar
Birdie
I don't believe it it useless with or without cats. It brings up your engine and fluids up to optimal temps a little sooner. Once it drop it's a bit safer to drive. I mean like you shouldn't start it and take off flooring it for the fact that you will probably blow something due to warping the metal from cold to hot so fast.
My personal number one reason to keep it is because when it idles down I know that the oil has had enough time to lube every thing back up after it has been setting overnight.I really want my car to last.
Old Aug 31, 2020 | 09:05 AM
dirtnapper56's Avatar
dirtnapper56
Don't do this mod! Your engine does this to prevent wear. The longer your engine is cold, the more wear it takes on a cold start. It's basically cars 101 that our cars do this for a reason. Doing this mod is just asking for engine problems down the line way sooner than you think.
Old Aug 31, 2020 | 09:55 PM
PNW_IPL's Avatar
PNW_IPL
Not really.
Its for emissions.
Vena14
Buying & Leasing
Jun 30, 2015 08:54 PM
6chr0nic4
Dec 6, 2012 03:28 AM
