Paddle Shifters
Old Feb 12, 2010 | 09:19 PM
pro-gadgeter's Avatar
pro-gadgeter
Paddle Shifters
Has anyone tried paddle shifters off of ebay?
Old Apr 5, 2010 | 07:23 PM
Ike427's Avatar
Ike427
If you are referring to Riverside Infiniti in California, yes I bought mine there. They shipped a complete kit for black interiors. Install isn't too difficult but although the shifters work fine for me they are little more than steering column decorations.
Old Apr 5, 2010 | 08:10 PM
LaWzLoL's Avatar
LaWzLoL
I got them a few months back. They were super easy to install. I didn't even have to remove the steering wheel. Do your own diligence, however, and ensure you have the pre-wiring under the column first.
There's a thread on the whole thing, just do a search...
Old Apr 24, 2010 | 02:05 AM
TinsleyC's Avatar
TinsleyC
Can paddle shifters be added to an 09 G37 Sedan Premium Journey with the willow color interior?
I search for "add paddle shifters 09 g37 sedan" and get a huge mix of topics. I've read several threads on this, and read the instructions, but still am not clear as to which models/years come pre-wired.
1) I don't want to buy the kit and tear into it just to find out I don't have the wiring.
2) Where do I find the willow kit? All I see are the black kits.
Thanks anyone...
Old May 3, 2010 | 04:35 PM
Ike427's Avatar
Ike427
I was able to loosen the lower steering column cover, use an inspection mirror and light to find the connector on the right side of the column and figured if there was a right side one the other side would be there too. It was covered with gray foam insulation and taped to prevent rattle or grounding. Keep searching this site or g-35 one of them has pics of the wire connectors. Or you can remove the cover completely and they are easily identified. Good luck
Old May 16, 2010 | 03:51 AM
bingpwr's Avatar
bingpwr
DIY: Installing Sport paddles - G35Driver
Old May 19, 2010 | 10:16 PM
bingpwr's Avatar
bingpwr
I got ****ed. I should have checked!!! Argh...now I have a kit with no wiring...btw, mine is a journey with premium package, and still no wiring...
Old May 27, 2010 | 04:25 PM
SaTa's Avatar
SaTa
Does anyone know if the paddles will work on the x coupe?
Old May 29, 2010 | 03:10 PM
bingpwr's Avatar
bingpwr
I highly suggest you go in there and check for wires yourself. All of the information I read pointed to the fact that Journey Coupes will work, but turns out it didn't for me. It's not that difficult to open it, but it's a pain to put it back on without scratching things.
37
Oct 17, 2020 11:12 AM
mikysee
Sep 28, 2015 11:18 AM
Allboutcali
Sep 26, 2015 03:43 PM
