FS: Bright Rear Turn Signal LEDs! Get crisp, bright, modern turn signals!
Old Feb 23, 2012 | 06:27 PM
Xenolith666's Avatar
Xenolith666
These will fit the brake lights as well yes? And no need for a resistor kit on those?
Old Feb 23, 2012 | 07:27 PM
Diode Dynamics's Avatar
Diode Dynamics
The brake/tail light should be LED...
Old Feb 29, 2012 | 11:41 PM
usaf512's Avatar
usaf512
How easy is it to install the rear turn.signal with the resistor.kit?
Old Mar 1, 2012 | 11:54 AM
Diode Dynamics
Just remove the taillights by removing the interior cover, then the three nuts on each screw stud on the tail light, pop the tail light out, swap the bulbs out, then attach the resistors. It shouldn't take more than 30 minutes. Thanks!
Old Mar 18, 2012 | 04:36 PM
Ontario G37S's Avatar
Ontario G37S
In case you wondered about daylight
As with many videos I haven't seen many daylight videos of aftermarket LED signals in the rear. So I thought I would post my own. Yes my car is dirty . This is a side by side comparison with the regular bulb and LED.
Now this LED bulb was not from DD, but it is very similar to DD's so you should get the same results if not better.
Ebay LED tailights for G37 Part 1 - YouTube
Ebay LED tailights for G37 Part 2 - YouTube
Old Apr 19, 2012 | 12:47 PM
nycty's Avatar
nycty
Where do you mount the resistors on the back? I know you can't mount it on plastic cuz it gets hot..=/ . I plan on changing out the front turn signals also to a 4w Switchback led, What resistor will i need, 3ohm or 6ohm? Thanks.
Old Apr 19, 2012 | 08:30 PM
Diode Dynamics
You can mount it anywhere, just make sure it is not touching the weaker black interior plastic. It gets hot like a light bulb. I'd recommend suspending it in place. I would recommend 6 ohm resistors.
Thanks!
Paul
Old Jul 24, 2012 | 02:58 PM
Diode Dynamics
Please feel free to post questions or comments!
Old Jul 25, 2012 | 02:02 AM
advan37's Avatar
advan37
You don't answer my pm . Thanks
Old Jul 25, 2012 | 02:05 AM
Diode Dynamics
Just replied, thanks.
Old Sep 4, 2012 | 01:16 AM
advan37's Avatar
advan37
not received yet .....
Old Sep 7, 2012 | 10:33 PM
Atlbrav1's Avatar
Atlbrav1
Sounds easy enough, but maybe not for everyone. Especially if you have to take care not to let the resistor touch the plastic and try to "suspend" it in there. Pics would certainly help. Do you have any you could post here or maybe a link to a video of a previous install, including best practices connecting the resistors. Thanks.
Old Sep 10, 2012 | 05:20 PM
Diode Dynamics
Actually, we are working on the video of resistor installation right now.
Paul
Old Nov 8, 2012 | 03:39 PM
  #29
TruLux's Avatar
TruLux
I can buy 2 sets of these for the taillights and headlights?
Old Nov 8, 2012 | 04:16 PM
  #30
Diode Dynamics
Yes, here's some links for you:
Coupe Front
2008-2013 Infiniti G37 Coupe Front Turn Signal LEDs - G37 - Infiniti - Listed by Vehicle - LED Bulbs
Coupe Rear
2008-2013 Infiniti G37 Coupe Rear Turn Signal LEDs - G37 - Infiniti - Listed by Vehicle - LED Bulbs
Sedan Front
2010-2013 Infiniti G37 Sedan Front Turn Signal LEDs - G37 - Infiniti - Listed by Vehicle - LED Bulbs
Sedan Rear
2009-2013 Infiniti G37 Sedan Rear Turn Signal LEDs - G37 - Infiniti - Listed by Vehicle - LED Bulbs
