Special New FREE Car Care Product every week at DetailedImage.com
Old May 14, 2014 | 08:16 AM
  #166
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
This week's Weekly Special is Menzerna Power Lock Polymer Sealant - 16 oz.
Use Coupon Code WSPOWER2014 to receive it for Free. A $29.99 value! Min spend $120. Offer ends 5/20/14 at 11:59 PM EST.
  • First true sealant produced by Menzerna
  • Long durable protection with a great shine!
  • Long lasting protection from durable polymer formula
  • Deep and glossy shine while easy to apply
Old May 21, 2014 | 08:28 AM
  #167
Detailed Image
This week's Weekly Special is Lake Country Red Foam Applicator Pad.
Use Coupon Code WSREDFO2114 to receive it for Free. A $2.49 value! Min spend $10. Offer ends 5/27/14 at 11:59 PM EST.
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old May 28, 2014 | 08:40 AM
  #168
Detailed Image
This week's Weekly Special is Sonax Wheel Cleaner Plus - 500 ml.
Use Coupon Code WSWHEEL2214 to receive it for Free. A $20.99 value! Min spend $90. Offer ends 6/3/14 at 11:59 PM EST.
  • Allows you to quickly and easily clean heavily contaminated wheels!
  • Acid-free and pH balanced
  • Sprays on clear, turns red as dirt & grime are removed
  • Safe for use on various wheel types (aluminum and alloys; painted, anodized and clear coated)
Old Jun 4, 2014 | 08:22 AM
  #169
Detailed Image
This week's Weekly Special is P21S Bodywork Conditioning Shampoo - 500 ml.
Use Coupon Code WSBODYW2314 to receive it for Free. A $11.99 value! Min spend $50. Offer ends 6/10/14 at 11:59 PM EST.
  • An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
  • Only a cap full of shampoo is needed in a 5 gallon bucket of water
  • The low sudsing formula does not make this a great shampoo for a foam gun
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old Jun 11, 2014 | 08:46 AM
  #170
Detailed Image
This week's Weekly Special is P21S Gel Wheel Cleaner - 500 ml Kit.
Use Coupon Code WSGELWH2414 to receive it for Free. A $19.99 value! Min spend $120. Offer ends 6/17/14 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old Jun 18, 2014 | 08:08 AM
  #171
Detailed Image
This week's Weekly Special is Einszett Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP2514 to receive it for Free. A $11.99 value! Min spend $50. Offer ends 6/24/14 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift *****, arm rests, leatherette, steering wheels and much more
Old Jun 25, 2014 | 08:12 AM
  #172
Detailed Image
This week's Weekly Special is Collinite 845 Insulator Wax - 16 oz.
Use Coupon Code WSINSUL2614 to receive it for Free. A $17.99 value! Min spend $125. Offer ends 7/1/14 at 11:59 PM EST.
  • A liquid carnauba wax that will keep your car protected like a sealant!
  • Very easy to apply and remove
  • Incredible levels of gloss that dramatically improves any color paint
  • Repels water, pollution, sun, salt, bugs and more
  • Can be applied to virtually any exterior finish
Old Jul 2, 2014 | 08:21 AM
  #173
Detailed Image
This week's Weekly Special is DI Accessories Fine Grade Clay - 100 g.
Use Coupon Code WSFINEG2714 to receive it for Free. A $10.99 value! Min spend $25. Offer ends 7/8/14 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
Old Jul 9, 2014 | 08:40 AM
  #174
Detailed Image
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel - 36" x 24".
Use Coupon Code WSWAFFL2814 to receive it for Free. A $17.99 value! Min spend $75. Offer ends 7/15/14 at 11:59 PM EST.
  • One of the best options for drying your vehicle safely and quickly
  • Continues to soak up large amounts of water even after it's damp or wet
  • A fine silk edging ensures this is a safe towel
  • This towel can hold up to 10 times its weight with water
  • Use this towel with the sheeting method for the most efficient drying process
  • 480 GSM
Old Jul 16, 2014 | 08:06 AM
  #175
Detailed Image
Use Coupon Code WSFINEG2914 to receive it for Free. A $10.99 value! Min spend $15. Offer ends 7/22/14 at 11:59 PM EST.
Old Jul 30, 2014 | 08:43 AM
  #176
Detailed Image
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL3114 to receive it for Free. A $15.99 value! Min spend $55. Offer ends 8/5/14 at 11:59 PM EST.
  • Sonax Wheel Cleaner 2 pack & Bonus Dashboard Cleaner ONLY $30!!!
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
Old Aug 6, 2014 | 08:47 AM
  #177
Detailed Image
This week's Weekly Special is 3M Automotive Performance Masking Tape - 18 mm.
Use Coupon Code WSAUTOM3214 to receive it for Free. A $3.99 value! Min spend $20. Offer ends 8/12/14 at 11:59 PM EST.
  • Properly protect paint, trim, emblems, lights, adjacent panels and more when using a buffer
  • Very high quality tape, perfect for auto detailing
  • Instantly sticks on surfaces and releases without any residue left behind
  • Ensures you don't get the dreaded white stain on your trim
Old Aug 13, 2014 | 08:25 AM
  #178
Detailed Image
This week's Weekly Special is DI Accessories Medium Grade Clay Bar - 100 g.
Use Coupon Code WSMEDIU3314 to receive it for Free. A $7.99 value! Min spend $15. Offer ends 8/19/14 at 11:59 PM EST.
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
Old Aug 20, 2014 | 08:24 AM
  #179
Detailed Image
This week's Weekly Special is DI Accessories Terry Cloth Black Applicator Pad.
Use Coupon Code WSTERRY3414 to receive it for Free. A $1.49 value! Min spend $5. Offer ends 8/26/14 at 11:59 PM EST.
  • Works great with polishes, sealants, waxes, leather care products and more!
  • Durable design with soft exterior!
Old Aug 27, 2014 | 08:40 AM
  #180
Detailed Image
Use Coupon Code WSWAFFL3514 to receive it for Free. A $17.99 value! Min spend $75. Offer ends 9/2/14 at 11:59 PM EST.
  • 480 GSM
