Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old Jun 6, 2013 | 08:49 AM
  #616
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (June 6, 2013) is Meguiar's Final Inspection M34.
Regular Price for 16oz is $7.99. Today's price is $5.83!
Regular Price for 128oz is $29.99. Today's price is $21.89!
  • Great cleaning quick detailer to remove a light dusting, finger prints and light contamination safely
  • Use after polishing to wipe down dust residue or after a sealant or wax to ensure there is no excess product left behind
  • We recommend using M34 with an Ultra Plush Microfiber Towel
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Jun 7, 2013 | 08:24 AM
  #617
Detailed Image
Today's Daily special (June 7, 2013) is Raggtopp Convertible Top Cleaner - Fabric and Vinyl Tops.
Regular Price for 16 oz is $12.99. Today's price is $10.00!
  • Safely and effectively removes contamination from fabric and vinyl convertible tops
  • Endorsed by Haartz, the primary OEM for American and European make convertible tops
  • After treating the surface, we recommend agitating a stain with a brush or towel
Old Jun 10, 2013 | 07:09 AM
  #618
Detailed Image
Today's Daily special (June 10, 2013) is Brinkmann MaxFire Marine Dual LED Rechargeable Spotlight.
Regular Price is $29.99. Today's price is $23.79!
  • Brinkmann MaxFire Marine Dual LED Rechargeable Spotlight will easily reveal swirls, RIDS, holograms, etc.
  • A more durable light that every detailer should have!
  • Includes an 120V AC charging adapter and a 12V DC car charger with coiled cord
  • Get the best polishing results with the proper lighting
  • Uses a 6V 2.3 Ah rechargeable battery
Old Jun 11, 2013 | 08:05 AM
  #619
Detailed Image
Today's Daily special (June 11, 2013) is 22ple VX1 Signature Glass Coating.
Regular Price for 20 ml is $51.99. Today's price is $41.38!
Regular Price for 30 ml is $75.99. Today's price is $56.23!
Regular Price for 50 ml is $119.99. Today's price is $85.19!
  • Protect your paint for up to 24 months!
  • Semi-Permanent paint coating with an amazing level of gloss
  • Made of high silica-content glass that creates a really strong protective barrier
  • Comes in multiple sizes!
  • Releases contaminants so future washes are quick and easy
Old Jun 12, 2013 | 08:05 AM
  #620
Detailed Image
Today's Daily special (June 12, 2013) is DI Accessories Foam Lance.
Regular Price is $89.99. Today's price is $64.79!
  • Spray tons of suds all over your exterior quickly and easily
  • Pre-soaking the paint helps make washing safer and more effective
  • Can be used with most pressure washers from 700 - 3000 PSI
  • Adjustable nozzle for various spray patterns
Old Jun 13, 2013 | 08:29 AM
  #621
Detailed Image
Today's Daily special (June 13, 2013) is Menzerna Color Lock Carnauba Wax.
Regular Price for 16 oz is $19.99. Today's price is $14.89!
  • Liquid wax that provides durable protection and an amazing level of gloss
  • Use by itself or use it after the Menzerna Power Lock Polymer Sealant
  • Very easy to apply and remove
  • Rivals the classic look of other traditional carnauba paste waxes
Old Jun 14, 2013 | 08:09 AM
  #622
Detailed Image
Today's Daily special (June 14, 2013) is Gilmour Foamaster II Foam Gun.
Regular Price for 1/4 Gallon Tank is $59.99. Today's price is $44.39!
  • Helps minimize the addition of new imperfections by softening and separating contaminants before using your mitt
  • Pre-soak your car with a layer of sudsy shampoo instead of using your mitt on dry paint
  • Helps get shampoo in those hard to reach areas, such as in the wheel wells and engine bay
  • Change the dilution ratio with the spin of a dial on the Gilmour Foamaster II Foam Gun
Old Jun 17, 2013 | 07:05 AM
  #623
Detailed Image
Today's Daily special (June 17, 2013) is Little Trees New Car Air Freshener.
Regular Price is $0.99. Today's price is $0.73!
  • Instantly reminds you of the new car smell that is clean and fresh
  • Proudly made in the USA
  • Amazing scent that easily lasts several weeks
  • One of the most popular Little Trees scents
Old Jun 18, 2013 | 08:05 AM
  #624
Detailed Image
Today's Daily special (June 18, 2013) is Chemical Guys Metal Wax Polish and Protection.
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • Restore your metal surfaces to a brilliant shine and protects the finish all in one step
  • Ideal for polishing wheels, trim, bumpers, exhaust tips, etc. and use it around the home
  • Easy application gives you great results in less time
  • Leaves a protective layer behind that repels build ups and makes future cleanings easier
Old Jun 19, 2013 | 08:05 AM
  #625
Detailed Image
Today's Daily special (June 19, 2013) is DI Microfiber Car Wash Mitt.
Regular Price is $3.99. Today's price is $2.83!
  • Excellent wash mitt that is soft and paint safe
  • Very cost effective washing medium
  • Can be machine washed and dried afterward
Old Jun 21, 2013 | 08:29 AM
  #626
Detailed Image
Today's Daily special (June 21, 2013) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.95!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old Jun 24, 2013 | 07:24 AM
  #627
Detailed Image
Today's Daily special (June 24, 2013) is DI Accessories Chemical Resistant Spray Trigger.
Regular Price is $2.99. Today's price is $2.23!
  • A high quality trigger meant to withstand strong cleaning agents
  • Can spray a fine mist or a direct stream
  • Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
Old Jun 25, 2013 | 08:21 AM
  #628
Detailed Image
Today's Daily special (June 25, 2013) is DI Microfiber All Purpose Towel Black.
Regular Price for 16" x 16" is $3.99. Today's price is $2.91!
  • Finally a great black microfiber towel is available to detailers!
  • Paint safe and very effective towel inside and outside your vehicle
  • Wash with the Chemical Guys Microfiber Wash Cleaning Detergent to help the towels last for years in great condition
  • Store in a DI Accessories Reclosable Storage Bag to help prevent dust and dirt from collecting on the towel
Old Jun 26, 2013 | 08:07 AM
  #629
Detailed Image
Today's Daily special (June 26, 2013) is Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.27!
Regular Price for 3" is $13.99. Today's price is $10.35!
  • Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
  • This item includes 2x DA Microfiber Finishing Disc Buffing Pads
  • Outstanding polishing power that provides a high level of gloss
  • Microfiber buffing pads are changing the way detailers work
  • Use it with the Meguiar's Professional Backing Plate, 5" Product Code: W67DA, 6" Product Code: S6BP
Old Jun 28, 2013 | 07:58 AM
  #630
Detailed Image
Today's Daily special (June 28, 2013) is DI Accessories Swag Bag.
Regular Price is $5.99. Today's price is $4.37!
  • Durable nylon backpack is the perfect way to carry detailing products or any other items you desire
  • Easy cinch up shoulder straps keep valuables safe
  • Proudly display your love of Detailed Image!
