Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old Apr 25, 2013 | 08:19 AM
  #586
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (April 25, 2013) is CarPro Iron X Iron Remover ( IronX w/cherry scent ).
Regular Price for 500 ml is $19.99. Today's price is $15.20!
Regular Price for 1000 ml is $32.99. Today's price is $25.08!
Regular Price for 4 L is $99.99. Today's price is $85.00!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Apr 26, 2013 | 08:06 AM
  #587
Detailed Image
Today's Daily special (April 26, 2013) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.91!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Old Apr 29, 2013 | 07:06 AM
  #588
Detailed Image
Today's Daily special (April 29, 2013) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.56!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Old Apr 30, 2013 | 08:22 AM
  #589
Detailed Image
Today's Daily special (April 30, 2013) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old May 1, 2013 | 08:11 AM
  #590
Detailed Image
Today's Daily special (May 1, 2013) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.09!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old May 2, 2013 | 08:07 AM
  #591
Detailed Image
Today's Daily special (May 2, 2013) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.66!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old May 3, 2013 | 08:10 AM
  #592
Detailed Image
Today's Daily special (May 3, 2013) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.41!
  • Pocket size plastic scraper with one single edge razor blade
  • Quickly remove inspection stickers and registration stickers
  • Use for virtually any scraping, trimming, or cutting
  • Open or close with easy push button lock system
Old May 6, 2013 | 07:09 AM
  #593
Detailed Image
Today's Daily special (May 6, 2013) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.21!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
Old May 7, 2013 | 08:06 AM
  #594
Detailed Image
Today's Daily special (May 7, 2013) is DI Accessories Razor Blade.
Regular Price for 100 pack is $6.99. Today's price is $5.03!
  • 100 pack is an awesome value!
  • Fits all standard razor blade holders
  • Made in USA high carbon steel
  • Quickly remove contamination, stickers, etc.
  • Single edged design
Old May 8, 2013 | 08:19 AM
  #595
Detailed Image
Today's Daily special (May 8, 2013) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.29!
Regular Price for 128 oz is $29.99. Today's price is $24.92!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Old May 9, 2013 | 08:12 AM
  #596
Detailed Image
Today's Daily special (May 9, 2013) is Little Trees Royal Pine Air Freshener.
Regular Price is $0.99. Today's price is $0.71!
  • The original Little Trees scent that is still a favorite
  • Proudly made in the USA
  • Great scent that lasts several weeks
Old May 10, 2013 | 08:13 AM
  #597
Detailed Image
Today's Daily special (May 10, 2013) is DI Accessories Plastic Razor Blade.
Regular Price is $0.99. Today's price is $0.72!
  • Perfect to use on windows!
  • Quickly remove inspection stickers and registration stickers!
Old May 13, 2013 | 07:08 AM
  #598
Detailed Image
Today's Daily special (May 13, 2013) is Little Trees Wild Cherry Air Freshener.
Regular Price is $0.99. Today's price is $0.74!
  • A great cherry scented air freshener that everyone will love!
  • A fun and pleasant scent that easily lasts several weeks
Old May 14, 2013 | 08:07 AM
  #599
Detailed Image
Today's Daily special (May 14, 2013) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old May 15, 2013 | 08:03 AM
  #600
Detailed Image
Today's Daily special (May 15, 2013) is Stoner Trim Shine Vinyl & Plastic Coating.
Regular Price for 12oz is $5.99. Today's price is $4.37!
  • Restores and UV protects vinyl, plastic and rubber using a clear, colorless, non-greasy formula
  • Works great on faded trim, bumpers, in the engine bay, running boards, rubber moldings, AC vents and more
