Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
#1336
Today's Daily special (October 25, 2016) is Meguiar's Super Degreaser D108.
Regular Price for 128 oz is $19.99. Today's price is $15.29!
Regular Price for 5 Gallon is $89.99. Today's price is $66.36!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Quickly clean engine bays, wheel wells, tires, and other heavily contaminated areas
- Concentrated formula works effectively even at a 10:1 dilution ratio
- Allow Super Degreaser to dwell for 30 - 45 seconds before thoroughly rinsing with water
- Agitate heavily contaminated areas with a brush or towel
- Dilute and dispense using a 22 oz trigger spray bottle
#1337
Today's Daily special (October 26, 2016) is DI Brushes Pad Cleaning Brush.
Regular Price is $2.99. Today's price is $2.06!
- Safely and easily remove excess product from your pads
- Safe for use on all buffer pads
- 5/8" strong, yet gentle bristles
- Helps prolong the life of your pads
#1338
Today's Daily special (October 27, 2016) is Menzerna Medium Cut Polish MC 2500.
Regular Price for 8 oz is $19.99. Today's price is $14.45!
Regular Price for 32 oz is $44.99. Today's price is $32.97!
- An incredible one step polish!
- Finishes down very well creating a glossy appearance
- Excellent polishing power to remove swirls, oxidation, etc.
- A light to medium polish that can finish down like premium light polishes
#1339
Today's Daily special (October 28, 2016) is Sonax Wheel Cleaner Plus.
Regular Price for 500 ml is $20.99. Today's price is $15.07!
Regular Price for 25 L is $499.99. Today's price is $378.21!
Regular Price for 5 L is $129.99. Today's price is $93.36!
- Allows you to quickly and easily clean heavily contaminated wheels!
- Acid-free and pH balanced
- Sprays on clear, turns red as dirt & grime are removed
- Safe for use on various wheel types (aluminum and alloys; painted, anodized and clear coated)
#1340
Today's Daily special (October 31, 2016) is CarPro Ceriglass Glass Polish.
Regular Price for 500 ml is $19.99. Today's price is $15.99!
- Deep cleaning glass polish that works extremely well
- Helps remove water marks, acid rain, sap, bird drop, road grime, etc. from your glass
- Can be used by hand or with a buffer
- Buffer applications can remove light to medium swirls/scratches in the glass
#1341
Today's Daily special (November 2, 2016) is Meguiar's Plastic and Vinyl Coating D45.
Regular Price for 10 oz is $7.99. Today's price is $5.19!
- Protect and enhance your plastic and vinyl pieces
- Long lasting protection from cracking and fading
- Leaves behind a clean natural looking dark finish
- Easy to apply!
#1342
Today's Daily special (November 3, 2016) is DI Microfiber Mini-Towel.
Regular Price for 8" x 8" is $1.99. Today's price is $1.14!
- Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
- Perfect for keeping your sunglasses clean and free of fingerprints
- 200 GSM
#1343
Today's Daily special (November 7, 2016) is DI Accessories Precision Bug Scrubber.
Regular Price is $6.99. Today's price is $4.45!
- Helps you easily remove dirt, grime, bug splatter, and more
- Easy to hold, lightweight handle design
- Six sided shape makes cleaning a breeze
- Rinses clean with ease
#1344
Today's Daily special (November 8, 2016) is DI Microfiber Two Sided Large Towel.
Regular Price for 16" x 24" is $4.99. Today's price is $3.15!
- This two sided towel is perfect for cleaning a variety of surfaces!
- One of our largest microfiber towels measuring 16" x 24"
- Silk edging helps minimize adding imperfections to delicate surfaces
- We always recommend washing your microfiber products before the first use (ie DI Microfiber Micro-Restore Microfiber Detergent Concentrate)
- 365 GSM
#1345
Today's Daily special (November 9, 2016) is Lake Country Snappy Clean Boost Pad Cleaner.
Regular Price is $1.49. Today's price is $0.85!
- A citrus degreaser designed to help release product and contamination from foam pads
- Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
- To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
#1346
Today's Daily special (November 10, 2016) is Meguiar's Unigrit 3000 Foam Finishing Disc.
Regular Price for 6" is $8.99. Today's price is $6.08!
- Safely and easily remove deeper scratches and imperfections from your paint
- Spray the surface with water for lubrication
- Clean the pad frequently with water while sanding
- Start with the less aggressive pads and move up as needed
#1347
Today's Daily special (November 11, 2016) is Lake Country Force Orange Cutting Pad.
Regular Price for 5.5" is $7.99. Today's price is $5.51!
Regular Price for 6.5" is $9.99. Today's price is $6.69!
Regular Price for 3.5" is $4.99. Today's price is $3.36!
Regular Price for 2" is $6.99. Today's price is $3.70!
Regular Price for 1" is $6.99. Today's price is $3.66!
- Foam pad that removes light to medium imperfections when paired with a cutting polish
- Hybrid foam technology keeps the polish on the surface of the pad
- 1.25" thick pad is very user friendly
#1348
Today's Daily special (November 14, 2016) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.03!
- Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
- Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
- Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
- Do not apply in direct sunlight or hot glass, otherwise streaking may occur
#1349
Today's Daily special (November 15, 2016) is Lake Country Glass Polishing Disc.
Regular Price for 2.25" is $3.99. Today's price is $2.47!
Regular Price for 3" is $4.99. Today's price is $2.94!
Regular Price for 5" is $5.99. Today's price is $3.78!
Regular Price for 6" is $6.99. Today's price is $4.37!
- Polishing away ultra fine scratches, watermarks and other imperfections in your glass
- Can be used on rotary or dual action polishers
- Produces low heat for better results and durability
- Hook and loop backing for easy fastening
- Pair with the CarPro Ceriglass Glass Polish
#1350
Today's Daily special (November 16, 2016) is Meguiar's All Purpose Cleaner D101.
Regular Price for 128 oz is $14.99. Today's price is $10.72!
Regular Price for 5 Gallon is $59.99. Today's price is $44.40!
- Perfect for carpet, upholstery, vinyl and leather surfaces
- Concentrated formula works effectively at a 10:1 dilution ratio
- Agitate stubborn stains with a medium bristled brush for maximum results
- Exceptional value for detailers and enthusiasts
