Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old Apr 4, 2013 | 07:59 AM
  #571
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (April 4, 2013) is DI Accessories Plastic Razor Blade.
Regular Price is $0.99. Today's price is $0.73!
  • Perfect to use on windows!
  • Fits all standard razor blade holders
  • Single edged design
  • Quickly remove inspection stickers and registration stickers!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Apr 5, 2013 | 08:20 AM
  #572
Detailed Image
Today's Daily special (April 5, 2013) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $10.64!
Regular Price for 128 oz is $34.99. Today's price is $24.84!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Old Apr 8, 2013 | 07:02 AM
  #573
Detailed Image
Today's Daily special (April 8, 2013) is Optimum Opti-Lens Coating.
Regular Price for 10 cc is $59.99. Today's price is $45.00!
  • Easily protect your headlights from fading, yellowing, hazing, and road grime
  • Keep your headlights crystal clear for optimal clarity while driving
  • Unique resin based formula that bonds to the surface of your headlights for durable protection
  • Easy to apply to any smooth plastic surfaces
Old Apr 9, 2013 | 08:12 AM
  #574
Detailed Image
Today's Daily special (April 9, 2013) is DI Brushes All Purpose Exterior Brush.
Regular Price is $4.99. Today's price is $3.69!
  • Use it to safely clean the exterior of your vehicle
  • Soft and safe to use on various surfaces
  • Flagged-tip bristles are resistant to acids and detergents for added longevity
Old Apr 10, 2013 | 07:58 AM
  #575
Detailed Image
Today's Daily special (April 10, 2013) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $7.99. Today's price is $5.91!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Medium to heavy cutting polishes work great with a yellow cutting pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • You need to follow up with a lighter pad and polish combo afterward to remove haze on the surface
Old Apr 11, 2013 | 08:10 AM
  #576
Detailed Image
Today's Daily special (April 11, 2013) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $15.53!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Old Apr 11, 2013 | 08:46 AM
  #577
BosMaSwaG37's Avatar
BosMaSwaG37
Whats the g37 forum dicount code?
Old Apr 12, 2013 | 08:05 AM
  #578
Detailed Image
Today's Daily special (April 12, 2013) is DI Microfiber Autofiber Pocket Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.43!
  • Great microfiber towel with a unique paint safe design
  • Two large pockets help keep your hand in place while working side to side
  • Pockets helps protect your hand on both sides
  • Can be machine washed and dried
  • Saves you time while improving your results!
Old Apr 15, 2013 | 07:09 AM
  #579
Detailed Image
Today's Daily special (April 15, 2013) is Lake Country Detailing Stick.
Regular Price is $1.99. Today's price is $1.45!
  • Excellent tool for cleaning tough to reach areas
  • Rinse and re-use these sticks over and over again
  • Great tool for the front grill, exterior trim, engine bay, lug nuts, door jambs, side mirrors, etc.
  • Remove tough stains with the Lake Country Snappy Clean Pad Cleaner
  • Durable foam tip with 8" wooden handle
Old Apr 16, 2013 | 08:07 AM
  #580
Detailed Image
Today's Daily special (April 16, 2013) is Meguiar's Pad Conditioner Brush.
Regular Price is $13.99. Today's price is $10.35!
  • Helps remove excess product trapped in your buffing pad
  • Helps keep pads working in ideal condition
  • Safe on all foam pads and very easy to use!
Old Apr 18, 2013 | 08:16 AM
  #581
Detailed Image
Today's Daily special (April 18, 2013) is 303 Aerospace Protectant Wipes.
Regular Price is $7.99. Today's price is $5.95!
  • A convenient way to apply valuable UV protection
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • 40 Aerospace Protectant Wipes come in each bottle
  • Treated surfaces resist dust, soiling and staining plus it helps repel moisture
Old Apr 19, 2013 | 08:19 AM
  #582
Detailed Image
Today's Daily special (April 19, 2013) is DI Microfiber Black and Yellow Towel.
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
Old Apr 22, 2013 | 07:11 AM
  #583
Detailed Image
Today's Daily special (April 22, 2013) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.25!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Old Apr 23, 2013 | 08:06 AM
  #584
Detailed Image
Today's Daily special (April 23, 2013) is Meguiar's DA Microfiber Correction Compound.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
Regular Price for 32 oz is $34.99. Today's price is $25.54!
Regular Price for 128 oz is $84.99. Today's price is $63.32!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
Old Apr 24, 2013 | 08:20 AM
  #585
Detailed Image
Today's Daily special (April 24, 2013) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.79!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
